Need help have a vibration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by txinferno, May 2, 2020.
  1. May 2, 2020 at 8:05 PM
    txinferno
    txinferno [OP] Member
    south texas
    2018 dcsb 4x4 or inferno MT
    Weather tech,blackout wheel decals,blackout bedside decal,glove box and console organizer
    Hey guys need a little help. I went to the beach for some surf fishing. I ran into some very soft sand and my 2018 offroad started hopping, not alot but enough to cause my truck to have a vibraton once i got to the pavement. It is not a tire out of balance cause i i ve rotated them. Could i have damaged a shock or worse? I does not ride as smooth, i can feel every bump and imperfection in the road. I pushed down on each corner of the truck to see if it bounced which it did go up and down a couple of times, i only have 26000 miles. Could the bouncing cause damage to the shock? I saw another truck do the same thing and boy did the driveshaft bounce alot.i hope i did not damage that thing.any ideas? If so what would i look for.i just drives like i i driving on a very bumpy road,not a paved road.thanks fora help.
  2. May 2, 2020 at 8:08 PM
    Chako
    Chako Well-Known Member
    Utah
    1998 TRDOR M/T 2020 TRDOR M/T
    The vibration is probably related to the driveline. Could be a ujoint or something else.
  3. May 2, 2020 at 8:09 PM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    Does it go away in 4wd?
  4. May 2, 2020 at 8:13 PM
    gabbo2112
    gabbo2112 Well-Known Member
    New York
    2020 TRD Off Road
    Just speaking from personal experience just because you rotated The tires doesn’t mean you don’t have a tire that threw a wheel weight. May have sand and dirt built up in the inside of your rims. Try cleaning them up and have them rebalanced could be a simple fix if you didn’t have any issues prior to sand wheeling. Good luck keep us posted.
  5. May 2, 2020 at 8:13 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Check the carrier bearing on the driveshaft for play
    Chako likes this.
  6. May 2, 2020 at 8:15 PM
    txinferno
    south texas
    I really dont feel to much vibration till i hit about 50 to 60 mph on the highway and i am not in 4wd at that time i did not notice it when i was on the beach driving slow, and i was still in 4wd at that time.
  7. May 2, 2020 at 8:17 PM
    txinferno
    south texas
    I also checked all the wheels for wheel weights and they were all there.the inside and outside weights.
    gabbo2112 likes this.
  8. May 2, 2020 at 8:24 PM
    tcjacado
    tcjacado Well-Known Member
    Probably sand and or mud in the rear drums.
