Need Help. Headlight Is Fogged
Discussion in '1st Gen. Tacomas (1995-2004)' started by TonyDuran, Jul 25, 2011.
  1. Jul 25, 2011 at 5:14 PM
    TonyDuran
    TonyDuran [OP] New Member
    California
    01 Toyota Tacoma
    None
    Hey everyone.
    I hope I've posted this in the correct forum section. If not, please forgive me. I couldn't find the troubleshooting/problems section.
    Anyways, I own a 01 Toyota Tacoma, of which the headlight (passenger side) has gotten foggy. It's certainly not as transparent as the passenger side light. At first I wasn't sure why one was foggy and the other wasn't, but then I took a closer look at the foggy light and noticed a small crack on the outside casing. I believe this crack has allowed moisture to enter the light. I've heard of people restoring their headlights with special DIY kits, but I've decided to take the route of simply replacing the light with an aftermarket light from an online store. I found two sites that I particularly liked, but I'm unsure of whether or not they are legitimate businesses. Furthermore, I don't want to fall prey to a scam. Has anyone purchased from either of these sites and can verify that they are a legitimate business? The following parts match the OEM number of the one I need. Thanks in advance.
    http://www.autolightcenter.com/toyota/tacoma/headlights.html#MTQ1MDY
    or
    http://www.collisionpartsexpert.com/product/23480
  2. Jul 25, 2011 at 5:16 PM
    darkgreentaco
    darkgreentaco XXXL Member
    NorCaL
    Timberland Rocket
    King RR C/O's, Extra mustard, All-Pro expdtn Leaf, sesame seed bun, Icon UCA's Fox Resi's BAMFsliders, sweet candy coating, LCAskids, diffcover 17" Addicts Yukon 4.56 Mt/r kevlar
    Welcome to Tacoma World.
  3. Jul 25, 2011 at 5:32 PM
    jrdriver8
    jrdriver8 Active Member
    Ma
    2002 Tacoma PreRunner
    Stock
    I agree with replacing it. My 02's are a little hazy and I will replace them eventually. I used an aftermarket set on my 02 Camry and they did not fit the car as well. I had to use a dremel tool to remove a small piece to get them to fit. Just make sure they are from a reputable vendor and you should be fine.
  4. Jul 25, 2011 at 5:45 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Ebay lights are pretty good, the crystal ones give better output and there actually fairly good quality.
    You can get a set of Crystals for like $100 shipped on Ebay if you look around.
    There actually cheaper for your 01 I believe..then my 99.
    You can always bake the light at 300 degrees for 8-9 mins, then take it out..pull it apart from the sealant, clean moisture out, repair crack with epoxy or plastic resin...then put them back in oven and heat em up..then re-seal them.
    It's sort of a hassle, but a fun project if you got time and patience..:cool:
  5. Jul 25, 2011 at 5:48 PM
    JayARRGHH
    JayARRGHH Well-Known Member
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    285/75/R16 Eldarado MTZ, Alpine CDE-102 Deck, DIY Snorkel, 2" Spacer Lift, Uniden Bearcat 880 CB, Custom over head console w/ map lights, CB Mount, and external CB speaker, 2 12" Kenwood Subwoofers, 300 Watt Alpine Amp, Alpine 3" lift 500# capacity
    Use rockauto.com and automotix.com rockauto.com is better in my opinion.
  6. Jul 25, 2011 at 6:14 PM
    meatman
    meatman I deal with dead animals
    Greg
    Murphy N.C.
    (built) 04 Tacoma SR5 4x4 and 01 TRD 4x4 DD
    Don't forget about the TW discount at rockauto!
  7. Jul 26, 2011 at 3:13 AM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    Did not know there was one! SWEET. thanks! haha how do i get it??
  8. Jul 26, 2011 at 3:30 AM
    justinw
    justinw Well-Known Member
    justin
    richmond
    08 SR5 progress
    tonneau cover bug sheild Husky mats 2 1/2 in front 2 1/2 in rear
    Wet sand with 500 then 800 then 1200 then 3000 allllll wet sanding make sure it stays wet.. Then dry it off and buff it.. Come out brand new.. Seems like a long process but takes me maybe 45 min. to do 2 of them.. Lay a coat of wax over top of them and u good to go.
  9. Jul 26, 2011 at 2:47 PM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    he has a crack in it though, otherwise i would just get the maguires headlight restoration kit. works like a charm and takes like 3 minutes. you attach it to a drill.
  10. Jul 26, 2011 at 2:49 PM
    tacoman355
    tacoman355 WORD!?!
    Tyler
    Hampton,VA
    03 Reg Cab Taco
    sold....
    rockauto.com, replaced both of mine for like $70 shipped and had them for a year now. crystal clear still, no fogging or hazing. plus rockauto has awesome customer service
  11. Jul 26, 2011 at 2:52 PM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    wicked awesome. I ordered a crucial part that was the deal breaker for me using them and like an hour after i ordered called me to apologize that they didnt have it and couldnt find it, which i was pissed about but appreciated so i could look elsewhere.
  12. Jul 26, 2011 at 5:53 PM
    justinw
    justin
    richmond
    08 SR5 progress
    iv never used it before.. i had a VW Jetta and started messin round just to see wat would happen and started sanding on the headlights then laid a nice thick layer of clear coat on em and they were brand new headlights and after bout 2 years or so they never changed.. but thats a little bit of work.. i do use maguires wax tho to do my truck and LOVE it..
  13. Jul 26, 2011 at 5:56 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    Without wet sanding, the first heat wave you get..it will fog/dull up and cloudy the outside.
    It only takes 20 mins to wet sand them..super easy..then I hit it with plastic polish, then normal wax after.
    Look brand new..but 98-00 headlights already have that weird privacy glass effect type thing inside..so it's impossible to get them "crystal clear"
    on OEM lights..
  14. Jul 26, 2011 at 6:05 PM
    clothar
    clothar Well-Known Member
    Vancouver
    98 V6 4WD Xtra Cab Limited
  15. Jul 27, 2011 at 3:26 PM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    Anything Maguires i love haha, I have a 2003 and i used the drill headlight restoration kit thing and with like 1 minute on each it made em crsytal clear and has been for about 6 months or so now, and its gotten up to 110 degrees here in Boston, believe it or not. Last week it was 100-110 all week. Then back down to like 60. thank you new england.
  16. Jul 28, 2011 at 7:31 AM
    HeadlampRevamp
    HeadlampRevamp Well-Known Member
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    This will not help him if it is a moisture issue.
