Need Help: Hood won't release or open
Discussion in 'Technical Chat' started by Patrol, Apr 20, 2014.
  1. Apr 20, 2014 at 12:16 PM
    Patrol
    Patrol [OP] Member
    Canada
    2002 Prerunner
    The release under the steering wheel isn't doing anything, and the hood catch in the grill won't release it so I can't open the hood.
    Anybody encountered this before?
  2. Apr 20, 2014 at 5:40 PM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    There should be a cable behind dash release. Maybe it isn't in slot. You can pull the end of the cable with pliers and should work. Otherwise you have to do threw front.
  3. Aug 22, 2015 at 7:57 PM
    cfrepro
    cfrepro Member
    Florida
    02 SR5
    How do I go through the front? Cable won't work. Battery dead.
  4. Aug 23, 2015 at 4:48 PM
    lock
    lock Well-Known Member
    greg
    N.W.OHIO
    tacoma
    I had this happen on a f-150. Hadn't opened the hood in a couple months, I have a sports car and during nice weather the truck sits.
    The latch had a small amount of rust that wouldn't release.
    Solution, with a helper holding the release under the dash open, I crawled under the bumper with a hammer and piece of rebar. Thread the rebar up til it rest on the latch and tap until it releases.
    If this doesn't work I would remove bumper and work up until I could access the latch.
    Can you access the grill and remove with the bumper in place?
    This is if you can't open useing Andy's advise.
    scottalot likes this.
  5. Aug 23, 2015 at 6:56 PM
    cfrepro
    cfrepro Member
    Florida
    02 SR5
    The release latch cable is not retracting. Everything appears to be hooked up.
