Need help : how to remove old paint from bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by black_cukui, Aug 12, 2015.
  1. Aug 13, 2015 at 9:20 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Maybe he'll try that also.
    Turbo tips are for noobs.
    You can scar concrete with less than 2000 psi and a 30 degree tip.
  2. Aug 13, 2015 at 9:22 AM
    medic2230
    Murph
    Bama! Roll Tide
    I'm sure most people don't have the 4000 psi jobbers anyway so it's a different ballgame when they are using the residential 2300 psi pressure washers. I agree with you and believe the pressure washer is the way to go. I know when I use mine which is a 4000 psi I know I can't get right on top of something cause it can easily cut through concrete.
    ducati[QUOTED] likes this.
  3. Aug 13, 2015 at 9:24 AM
    T4RFTMFW
    But LineX.
  4. Aug 13, 2015 at 10:23 AM
    rmorse
    rmorse Well-Known Member
    Bobby
    Bowie, MD
    2015 Blue Ribbon Metallic Access Cab TRD Sport
    As long as you don't step on the tailgate.
    T4RFTMFW likes this.
  5. Aug 13, 2015 at 10:34 AM
    T4RFTMFW
    Nicely played.
  6. Aug 17, 2015 at 11:25 PM
    black_cukui
    black_cukui [OP] Well-Known Member
    Patrick
    Riverside, ca
    2010 T4R SR5
    Finally got around to getting a quote to Line X my bed.. $660.00!!! ill have to wait it out LOL
  7. Aug 28, 2015 at 11:02 AM
    black_cukui
    Patrick
    Riverside, ca
    2010 T4R SR5
    UPDATE:
    I called a 2 of the 3 LINE X shops in my area and they DO NOT line X a composite bed. I got an OK from the 3rd shop, but they want to see it first. Ill keep you guys posted on what he says.
  8. Aug 28, 2015 at 11:04 AM
    T4RFTMFW
    Pretty sure someone else has LineX on their second gen, and they got all hated on for it.
    Look forward to a result, whatever it may be.
  9. Aug 28, 2015 at 11:07 AM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    [/QUOTE]
    jmaack[QUOTED] likes this.
  10. Aug 28, 2015 at 11:12 AM
    black_cukui
    Patrick
    Riverside, ca
    2010 T4R SR5
  11. Aug 28, 2015 at 11:51 AM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    You have some good ideas in this thread. I would try a few of them in small areas to see what effect that particular solvent, cleaner, etc. has on the bed. Same thing with the pressure washer. It may work great, maybe not, but try it a little first and see how it does. Start farther away and approach the bed surface slowly and carefully and see what happens. I like using the magic eraser and have had good results with it though I have not tried it in this type of a situation. At a cost of $500 to coat the bed vs. $50 to potentially clean the bed I would be trying the $50 route first. My two cents, which is about what it is worth.
  12. Aug 28, 2015 at 12:07 PM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    What would be the use for such high pressure?
  13. Aug 28, 2015 at 12:27 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    (cough) raptor liner (cough)
  14. Aug 28, 2015 at 12:39 PM
    ducati
    ducati thie-trickster
    Carlsbad, CA
    2013 DC 4x4 Black
    Icon coils, Squeaky dakars, Thule rack, tinted windows, weathertech rain guards, Demello off road front bumper, warn winch, shok sound deadening.
    Many different applications. Mostly industrial though. Such as concrete anything manufacturing plants. Not very practical for a home owner.
  15. Aug 28, 2015 at 12:54 PM
    #35
    T4RFTMFW
    Hardly. PSI ratings are at 0 degrees. With a 50 degree tip it drops considerably, as does even a 35 degree and 15 degree tip.
    Additionally, each foot of high pressure water line drops pressure still, so if you're using a 60 ft line and need to go further, adding an additional 60 ft line drops pressures quite a bit.
    4000 psi is a hefty machine, but it's not what I would call overkill.
  16. Aug 28, 2015 at 1:59 PM
    #36
    ducati
    Carlsbad, CA
    2013 DC 4x4 Black
    OK that's fine. Doesn't make a difference to me what pressure washer you use. I'm not a pressure washer guru. Nor do I care to be. I used a 4000psi hotsy at work all the time. At home I have a cheap 3000psi Costco one. Seems to work fine for home duties. Not sure if you're joking or being serious. You're taking cleaning stuff a lot more serious than I do if you're not.
  17. Aug 28, 2015 at 2:01 PM
    #37
    T4RFTMFW
    I use them less than you do, I don't care, and I was only making a comment on your statement that 4000 PSI isn't practical for a home owner being wholly incorrect.
  18. Aug 28, 2015 at 2:07 PM
    #38
    medic2230
    Murph
    Bama! Roll Tide
    I've used it for everything from cleaning the house before painting to cleaning all the concrete around the house. Cleaned the mud off the underside of the truck with it too. It cleans a lot faster than the smaller units.
  19. Aug 28, 2015 at 2:08 PM
    #39
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Whatever solvent you use, try to keep it damp with the solvent for a good 5 min. and give it a chance to work. Some people wipe it on and off too quick and get discouraged. Regular old paint thinner should work. After all it is paint.
  20. Aug 28, 2015 at 2:08 PM
    #40
    T4RFTMFW
    FWIW understanding how PSI ratings work and how pressure drops over distance (among other reasons) isn't exactly taking something "too seriously."
    Pretty basic concepts of understanding, really, unless you're limiting yourself to "put gas in, turn water on, pressure wash" way of thinking.
    DoorDing likes this.
