Need help. I have 2006 quad cab prerunner V6.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dpytacoma, Aug 19, 2025.
  1. Aug 19, 2025 at 6:07 PM
    Dpytacoma
    Dpytacoma [OP] Member
    Dan
    2006 Tacoma quad cab prerunner
    Minor
    I am new to this forum.
    While driving I hear I pitch whining.
    I put in in neutral an coast the noise goes away or lessens that I cannot hear.
    What could universal joints, or drive shaft center bushing/ bearing?
    Thank you for the suggestions.
  2. Aug 19, 2025 at 6:23 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    A whine on acceleration would have me inspecting the rear end.
    Not saying it is, but the words “whine, coast, neutral,” are indicative of rear end symptoms.
    But not knowing where the sound is “coming from” doesn’t help.
    Do you have any idea where it sounds like it is originating from?
    wi_taco likes this.
  3. Aug 20, 2025 at 9:09 AM
    safaridave
    safaridave Well-Known Member
    Richmond, Virginia
    06 Prerunner TRD OffRoad
    Maybe water pump? that would be engine RPM dependent. see if the noise is front or back of vehicle. could also be serpentine belt idler pulleys.
    wi_taco likes this.
  4. Aug 20, 2025 at 3:50 PM
    Dpytacoma
    Dan
    Minor
    The noise is coming from the rear.
    Check oil level in the diff. Good level and clear..
    I tried moving the drive shaft to check universal joints and the center driveshaft bearing.
    Back Wheel bearing orc transmission.?
    I will check the trans oil this weekend. My scan gage tells me the trans temp is in range and no warning on the trans or engine. Engine temp is in range.
    Liftrd the hood. Had my wife raise the rpms so slowly from 900 to 4000. Heard nothing unusual. No wining noise.
    I put in neutral and coast. No noise. When put in drive and give gas, increase rpm the whining get loader, not screaming.
    Please help. I am dumb founded about this.
    How to check if a wheel bearing(s) is bad or drive shaft bearing is bad (looks new). Bought the truck in 2022. It has now 175,000 miles on it.
    Suggestions are welcomed.
    Thank you so much.
  5. Aug 26, 2025 at 12:00 PM
    safaridave
    Richmond, Virginia
    so the noise is noticeable and steady under load and is coming from the rear of the vehicle. My guess is center carrier bearing, one of the u-joints is going bad or you have some issue in the diff.
    Jimmyh likes this.
  6. Aug 26, 2025 at 12:11 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Lift the rear off the ground, run the wheels up to speed and listen with a stethoscope. Listen around the differential, the wheel bearings and the driveshaft center bearing
    TnShooter likes this.
  7. Aug 26, 2025 at 12:11 PM
    Dpytacoma
    Dan
    Minor
    Just had the universal joints and center carrier replaced. Still some noise.
  8. Aug 26, 2025 at 12:15 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Still need to listen around with a stethoscope. Just because the parts are new doesn't mean they aren't making noise
