Need help identifing topper manufacturer
Discussion in '1st Gen. Tacomas (1995-2004)' started by mediagirl, Oct 28, 2016.
  1. Nov 7, 2016 at 1:02 PM
    mediagirl
    mediagirl [OP] Member
    It's got a convex curve to the glass which is the challenge. The glass companies that I've talked to can't do custom curves like that.
    Is Dave the guy usually working in the shop? He didn't know the brand of the camper and sent me to the other guy on Osuna.
  2. Nov 7, 2016 at 1:50 PM
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    I wonder if any leer or snugtop camper windows fit the same dimensions as yours. Might make another visit to each store and see?
  3. Nov 18, 2019 at 1:01 PM
    USMCGySgtV
    USMCGySgtV New Member
    2002 Tacoma
    None
    Its a Century, Royal model
    I have the same model and after lots of research. they don't support this model anymore. so getting glass for it doesn't seem possible. let me know if you found a place as I am in need of back glass too
    Hamer95USA likes this.
  4. Nov 18, 2019 at 1:10 PM
    Hamer95USA
    Hamer95USA Well-Known Member
    1999 Toyota Tacoma 4x4 SR5 extended cab reborn!
    Complete OME suspension kit, Used low mileage V6 engine swap, black powder coated Chou Seiki T15x7JJ, ARB deluxe bumper, Smitty Bilt nerf bars, Weathertech floor liners, Torklift tiedowns
    Have you considered getting a sheet of plexiglass with tint and having it custom cut & drilled to your specifications? I know the local TAPP Plastics can come up with something. Or you'll have to look online/call/email every place that might have an NOS tempered glass door for your camper shell. I had a similiar issue with Glasstite/Raven (owned by EFX Body) trying to get hardware for the sliding glass window handles. I ended up going to TAPP Plastics to fabricate a part for me. :(
  5. Nov 18, 2019 at 2:07 PM
    USMCGySgtV
    2002 Tacoma
    None
    @Hamer95USA I made one out of tinted lexan and reinforced it. its works pretty good but would still like the actual glass if I could find it. lol
  6. Nov 18, 2019 at 2:15 PM
    Hamer95USA
    I've seen some very neglected truck shells and some people have had to improvise with using plexiglas/lexan/sheet plywood to replace the broken truck shell window that was vandalized or broke by accident. I was lucky when Glasstite was still in business when someone broke the side window of my truck shell in a vehicle theft. I was able to contact the dealer that I bought the shell from who contacted the manufacturer and was able to buy a new side window from the manufacturer. The same thing when I broke the front shell window by throwing my stand into the back of the truck without thinking about it.:(
  7. Nov 18, 2019 at 2:23 PM
    USMCGySgtV
    2002 Tacoma
    None
    Yep. I have contacted the Century and they changed glass companies because the original glass company closed up and the new company wont support anything older than a couple of years. the biggest problem is that the rear door glass has a slight curve in it and no glass companies are able to curve/bend the glass for it. And flat glass wont seal up properly.
  8. Nov 18, 2019 at 2:28 PM
    Hamer95USA
    That truly sucks that the current glass company won't support the older truck shells. I had a hard time getting little plastic handles for the front sliding glass window of my Glasstite shell so I can understand your frustration about getting the correct rear glass door for your shell.
  9. Oct 27, 2022 at 10:42 AM
    Sr Raven Wolf
    Sr Raven Wolf New Member
    Subaru baja
    Looks to be ARE i have a used camper shell from them that requires the same looking door mounts that im looking for. That might be a serial# on the ceiling
  10. Oct 28, 2022 at 8:52 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    Here's the circa 2004 ARE (CX-series, I believe) canopy on my 2003 DC TRD. Lots of differences between yours and my CX-series cap. If it's ARE, it's a different model.
    This tag is on the roof, centered near the back window.
  11. Oct 28, 2022 at 9:15 AM
    Heartland Hunter
    Heartland Hunter Well-Known Member
    Danny
    2001 Tacoma
    100% ARE i have one as well
  12. Oct 28, 2022 at 9:23 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    OP hasn't been back since 2016, when this thread was started :bananadead:
    4xdog likes this.
  13. Oct 28, 2022 at 9:46 AM
    4xdog
    Santa Fe, NM
    :) True -- but the subject of Gen 1 shells comes up from time to time, especially as companies take them out of their product lines and new owners continue to look for 'em. Hopefully the op has long resolved the problem, but having canopy/bed cap/camper shell info here on TW will probably help someone down the line.
    six5crèéd[QUOTED] likes this.
  14. Oct 28, 2022 at 9:50 AM
    leueddie
    leueddie Well-Known Member
    Edwin
    WA
    Looks like a century to me. Guy I work with has one that's red too. Looks the same.
