Need help identifying missing parts
Discussion in '1st Gen. Tacomas (1995-2004)' started by PSpider25, May 22, 2015.
  1. May 22, 2015 at 12:41 PM
    PSpider25
    PSpider25 [OP] Member
    Can anyone help determine what the strap is on the driveshaft? Is this something to worry about when making a purchase? Also it looks likethe cat conv heat shield is gone?
  2. May 22, 2015 at 12:46 PM
    gearcruncher
    Canadain bumper technician
    The strap needs to go . Wondering why its there ?
    The anti sway on the front end can be replaced.
    The heat shield above the cat converter can be replaced
  3. May 22, 2015 at 12:50 PM
    PSpider25
    Should I be concerned that someone put it (strap) there as some kind of temp fix?
  4. May 22, 2015 at 1:18 PM
    Warped
    Warped N4LJ
    Jim
    Eastern Ky
    2024 Tacoma TRD Off Road
    :notsure:
    The only strap I see is the one holding up the fuel tank.
    Snowman likes this.
  5. May 22, 2015 at 1:43 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Same
    Looks like it needs an exhaust hanger welded on, sway bar is probably fine, but just needs a cleaning/painting, and as stated above the shield can be replaced if you care that much (I wouldnt)
  6. May 22, 2015 at 3:40 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    he hung the drive shaft with the strap to replace the u-joint but leaving it there says worlds about the kind of work he does when he works on the truck. missing heat shield most likely because he was too lazy to replace it or his solution to it rattling.
    i fear what you see missing and wrong is only the tip of the iceberg and there may be many hidden problems not yet discovered.
    I would walk away from that one and keep looking, it screams money pit and endless problems to me
  7. May 22, 2015 at 4:47 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Yeah what strap!?
  8. May 22, 2015 at 4:51 PM
    PSpider25
    I was wrong. If you zoom in the strap is only on the tank. There is some kind of rubber wrap around the shaft that makes it look like the tank strap is on the shaft.
    What is the purpose of the heat shield? Is it needed? The exhaust system looks relatively new.
  9. May 23, 2015 at 2:42 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    The grease darkened area of the driveshaft makes it look like something is holding the driveshaft.
    I can see this is going to be a project if you know that going in and the price is right go for it.
    If the frame is not yet through yet by the spring hangers another Pa winter or two it will be.
  10. May 23, 2015 at 2:55 PM
    PSpider25
    The guy just told me he was going to go ahead and repaint the bed body and tailgate.imagejpeg_31.jpgimagejpeg_30.jpg
  11. May 23, 2015 at 3:08 PM
    bubbabud
    bubbabud Well-Known Member
    Bob
    Tonopah AZ
    13 tacoma TRD Off road.ARE shell no rust anywhere period.
    2 in spacer lift front 2, in AAL rear [tundra leaf] , flip up tow mirrors, ARE shell electric brake controller and cooper ATP 265/r70x16 tires on stock TRD wheels
    I would hit the ground running and don't look back this truck is a bubble gum and bailing wire rust bucket and if was cared for the way it appears which is not at all your buying a project so unless you are getting it at a project price steer clear just my $.02 worth
  12. May 23, 2015 at 3:35 PM
    PSpider25
    Hi. How can you tell the spring hangers will be shot soon? It got a new frame under the recall in 2011.
  13. May 23, 2015 at 3:38 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I see no strap anywhere. I don't see anything wrong with the truck that isn't normal for a 10+ year old vehicle that cannot be fixed or isn't to be expected.
  14. May 23, 2015 at 3:39 PM
    PSpider25
    More pics...
    imagejpeg_14.jpg imagejpeg_0.jpg imagejpeg_7.jpg imagejpeg_1.jpg imagejpeg_9.jpg
  15. May 23, 2015 at 3:46 PM
    PSpider25
    Has 145k miles...i think he wants $10k
    the diff lock doesn't engage either
    these first gen double cab 4x4's are hard to find!
  16. May 23, 2015 at 3:48 PM
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    Looks fine to me..
  17. May 23, 2015 at 4:10 PM
    2004TacomaSR5
    Jon
    Montana
    I agree, I wouldn't be afraid of buying that. 10k is a deal for a 4WD first gen double cab with under 200k miles still.
  18. May 23, 2015 at 4:59 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    I believe this is the strap OP is referring to.
  19. May 23, 2015 at 5:12 PM
    2004TacomaSR5
    Jon
    Montana
    It's supposed to be there, it holds the fuel tank. The grease marks around the driveline slip yoke are normal too. Thanks to Tacoma's lovely axle wrap you have to constantly add grease to that thing.
  20. May 23, 2015 at 5:28 PM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    Lol the optical illusion really got quite a few people on this one..
