Need help identifying this grinding noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kuhner32, May 22, 2022.
  1. May 22, 2022 at 2:00 PM
    Kuhner32
    Kuhner32 [OP] New Member
    Adam
    2013 Double Cap TRD Sport
    My truck randomly started making a grinding noise coming from the front drivers side that I have had zero luck diagnosing.
    I've attached a link to a video of the noise being referenced, and any insight or ideas on what it could be would be appreciated.
    https://youtube.com/shorts/V3tAvei7ff0?feature=share
    For reference, here is what I have assessed/tested already:
    1.) Brake dust shields - all straight with no signs of grinding/wear.
    2.) Skid plate/Bull Bar - removed both and the noise still persisted
    3.) Wheel bearings - Had them inspected, no issue or excess wear
    4.) I put the truck on jack stands and performed the same tests (changing gears, accelerating, braking, steering) and no grinding noise could be replicated, but as soon as I put it down on the ground the grinding continued immediately.
    It's driving me insane, so I'm open to any and all possibilities - thanks!!!
  2. May 22, 2022 at 2:23 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    kind of has a wind instrument quality
    pinhole leak catching the edge of a thin piece of metal like the heat shield on the cat?
    whatstcp likes this.
  3. May 22, 2022 at 8:52 PM
    Waasheem
    Waasheem
    2007 xrunner
    A couple suggestions.
    If you suspect it to be coming from below, drive on something elevated like in a parking structure, one guy driving, one guy standing in a spot he can see underneath with a flashlight.
    If you think you’ll find it from above, USE CAUTION ON THIS ONE. Drive very slowly near someone standing on a ladder with the hood open.
  4. May 22, 2022 at 8:59 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds like a heat shield vibrating to me.
  5. May 26, 2022 at 5:33 AM
    Kuhner32
    Adam
    Thanks all - going to take a stab at it this weekend, and will update with what I find!
