Need Help - I'm stuck on a lift project
Discussion in '1st Gen. Tacomas (1995-2004)' started by wndrboy777, Aug 29, 2010.
  1. Aug 29, 2010 at 4:16 PM
    wndrboy777
    wndrboy777 [OP] Member
    Albuquerque, NM
    2003 Xtracab V6; 2016 TRD DCOR
    1GT: Topper, rack, deckplate mod, ARB w/ Smittybuilt, CBI sliders and rear, Icon 2.5, Allpro leafs w/ Icon 2.0, Procomp Xtreme MT2 285/75/16; 3GT: CBI front w/ Oz Halo LB and Smittybuilt
    Currently trying to install a 3" lift - from coilovers went on easy, but the rear has been one huge frustration after another. I'm currently stuck - I have the new leafs on (finally), but now that I'm trying to install the new shock absorbers (Bilstein 5125), I can't get them on... The rubber bushing will insert on to the shock mount, and I can get it into the shock ok, but when the bushing is inside of the shock, it will not slide onto the mount. I tried putting the busing on the mount, then pulling the shock over it - no joy. I also force one with the bolt and a large washer, and now it's completely stuck - I can't get it to progress and I can't get it to come off. I decided to leave it and go to the other side, but I can't get it on. This is driving me nuts - any help would be huge.
    Stuck bushing/shock - lower mount post passenger side
    Lower mount post driver's side
    Upper mount post driver's side
  2. Aug 29, 2010 at 4:24 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    bump for a expert......:popcorn:
  3. Aug 29, 2010 at 4:31 PM
    jesus
    jesus Well-Known Member
    jesus
    bakersfield
    K&N ram intake & doug exs.
    I had to lube mine I don't reacall for sure b ut I think I put a bit odf wd40 to help slid them in
  4. Aug 29, 2010 at 4:51 PM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    Damn! That lower one looks rusted to hell!!! WD-40 can be corrosive to polymers and rubbers. Try a good slick grease.
  5. Aug 29, 2010 at 4:54 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
  6. Aug 29, 2010 at 6:14 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Maybe try sanding them down a bit, clean them, them get some lube on them.
    Mine were a biatch too. But It just needed some lube.
  7. Aug 30, 2010 at 2:40 AM
    SPOTSONTROUT
    SPOTSONTROUT Well-Known Member
    ROB
    SOUTHERN ONTARIO CANADA
    03 TRD Stolen
    OME 882,DAKAR LEAF PAC WITH ADDA LEAF,285 TOYO OPEN COUNTRY MT,RACELINE RENAGADES,DECK PLATE MOD, MANUAL HUB CONVERSION
    Use a little bit of dish soap . Should slide right on.
  8. Aug 30, 2010 at 10:48 AM
    scocar
    scocar hypotenoper
    Yup. Damn, that lower is rusty. I would sand that down a bit, then use a little grease (or liquid soap) to finesse them on. Put on the inner bushing first, then put the shock on, then put the outer bushing on. Don't try to hold it all together at once while trying to compress the shock...
    Maybe you are already doing this, but you can also lower or raise the axle to a spot where the shock is not loaded up and easier to manipulate.
  9. Aug 31, 2010 at 11:07 AM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    I put the bushings in the shock, lubed the bushing with soap where it slips on to the mount and then beat them on with a rubber mallet. I really had to beat on the end of the shock where the bushing goes. trying to push the bushing in to the shock will not work IMO.
  10. Aug 31, 2010 at 12:48 PM
    HBMurphy
    Paul
    So California Coast
    None
    That's exactly why, in my write-up - I opened up the rubber bushing with a wood bit - I don't want to see a crack develop on the lower shock boss.
  11. Aug 31, 2010 at 1:00 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    A little rust on shock post, ehh leave it alone , what then after sanding it off.
    Now you have bare metal unless you paint & let dry but moving on, use some Vaseline & ""thread" the bushing by hand "righty tighty" while using your mallet in even, firm taps. By threading it like a nut (or bolt ) just the action of twisting it will make the rubber contract (thus making it smaller) as you start it into place in shock eye....:cool:
  12. Aug 31, 2010 at 1:09 PM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    grind it down to knock the rust off and make sure you hit it with some rostoleam before it put the shocks on. Bushings are suppost to fit snug
  13. Aug 31, 2010 at 2:36 PM
    BRP27
    04 4X4 Tacoma SR5
    X2
    Grind the rust off and make the shaft smooth. you have some serious rust on the shaft.
  14. Aug 31, 2010 at 7:53 PM
    wndrboy777
    Albuquerque, NM
    thanks for the ideas everyone - I was able to sand a little bit of the rust off, and with some packing grease, the bushings slid right on. Lift is on, now just working on getting the bumper installed.
  15. Dec 21, 2014 at 8:33 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    Super Old thread I know, but I need some advice on installing some 5125s in the rear. It seams that the bushings that came with the shocks are not the proper ID and won't fit on the mounts. It doesn't look like I'll be able to just lube up the mounts and force them on either..
    Is this a viable solution --vv ... ... TIA
    Edit: well I said F'it and drilled them out to 3/4", figured the worst that could happen was I ruin them and have to buy new bushings..
    Anyway, it worked pretty well. I put some grease on the mounts and inside the bushings, and also used an extra washer on the bolt side of each mount to make up for the difference in the shock eyes/bushings. (The previous 5100s were a bit bigger ~3/16) I think the heat generated from drilling the bushings out actually helped make the more pliable and they slid on easier
  16. Dec 21, 2014 at 1:20 PM
    TIPICOTACO
    Tyler
    nw nj
    Here's how I did the washers
  17. Dec 21, 2014 at 1:28 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Thats fine & yeah the replacement bushings are the smaller I.D. bushings I usually drill out a little material from bushing , helps a ton..
  18. Dec 21, 2014 at 2:37 PM
    TIPICOTACO
    Tyler
    nw nj
    :thumbsup:
    So I didn't get the wrong bushings? They all need to be modified for 1st gens?
  19. Dec 21, 2014 at 2:49 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Yeah Bilstein quit getting the "Big eye" OEM type for 1st gens, they may still get them for you if requested but anymore they come with the smaller,newer designed bushings...
  20. Dec 21, 2014 at 3:03 PM
    TIPICOTACO
    Tyler
    nw nj
    Ah ok thanks for the clarification
