Need Help - Installed DTRL - Now some things don't work
Discussion in '2nd Gen. Tacomas (2005-2015)' started by joleger, Jul 3, 2010.
  1. Jul 3, 2010 at 12:40 PM
    joleger
    joleger [OP] Well-Known Member
    Saint John, NB
    2008 Access Cab 4x4 TRD Sport
    Hey Guys,
    Hopefully you can help me out.
    I just installed my DTRL and they work. :)
    However, now my gauges and radio don't work
    Other things that don't work
    - Truck doesn't give the warning beep when I put into reverse (man. trany)
    - No dash lights that indicate I am in 4H/4L
    - Odometer numbers don't display
    Did I really screw things up or did just blow a fuse?
    Thanks for your help.
    Cheers
    J.O.
    UPDATE: Found the problem. One of the connectors that I removed to get more room to work wasn't connected properly. I gave it a push and it clicked.
  2. Jul 3, 2010 at 12:46 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    it doesn't beep in reverse? you mean like a semi?
    how did you do the mod? did you tap into the wires near all the fuses in the cab or just hotwire it next to the battery fuse box?
  3. Jul 3, 2010 at 12:51 PM
    joleger
    Saint John, NB
    Sorry....let me clear.
    What I meant by "beep in reverse" is that when I put the truck into reverse, there is a short "beep" that comes from the console. It's like a "hey moron, you're in reverse" warning beep.
    I got the truck that way, it wasn't a mod.
  4. Jul 3, 2010 at 12:54 PM
    CopDoctor
    08 335i
    oh ok lol
    i'd go through and check your fuses, one of em may be blown. if you just hotwired the wires and ran a wire into the 3rd hole in your running lights then you can't mess anything up by doing that...if you did the whole fuse/relay deal then somethings probably just blown
  5. Jul 3, 2010 at 12:54 PM
    Krewblink
    Krewblink Well-Known Member
    Danny
    Long Beach
    05 toyo Prerunner
    Exhaust,Seat Covers, Intake
    i dont have that beep...
  6. Jul 3, 2010 at 12:56 PM
    Chad
    Chad Well-Known Member
    Chad
    Raleigh, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- BHLM -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- 09+ Access Cab Rear Headrest Removal
    He has an 08 and yours is an 05 so more than likely it was something added by Toyota in that three year span.
  7. Jul 3, 2010 at 12:59 PM
    joleger
    Saint John, NB
    I did the OEM fuse/relay thing...no hot wiring for me.
    I'll start checking the fuses. I must admit, I forgot to disconnect the battery when I first started so I most likely blew something.
    I'll give an update if I find anything.
  8. Jul 3, 2010 at 1:58 PM
    joleger
    Saint John, NB
    So basically as far as I can tell, my gauges and radio doesn't work. I tested (with a multimeter) the 7.5A fuse that said gauge and it was good. I also swapped the gauge fuse with the other 7.5A fuse in the box and still have the same results.
    I also tested both radio fuses in the box under the hood...they both tested good.
    I guess I will be opening up the dash again to see if I missed something.
  9. Jul 3, 2010 at 2:03 PM
    CopDoctor
    08 335i
    dang dude, no idea what's wrong. bump
  10. Jul 3, 2010 at 2:16 PM
    joleger
    Saint John, NB
    UPDATE: I'm an idiot
    I opened everything up again and one of the connectors wasn't pushed in all the way.
    Everything seems to be working again.
  11. Jul 3, 2010 at 2:54 PM
    CopDoctor
    08 335i
    lol hooray! it's ok it happens, like i told someone a few days ago, when installing my HID kit i grounded the setup to plastic
  12. Jul 5, 2010 at 1:45 PM
    duffy_north
    duffy_north Well-Known Member
    Duff
    Ontario, Canada
    2009 TRD
    JO, glad to see it worked out for you. I did mine a little while back and was a little uncertain myself pulling plastic and wires on my new truck, however, it worked out well except for scalping my index finger knuckle. Toughest part was getting the grey plug out, but finally got a screwdriver in there and it popped out slick.
    Duff
  13. Jul 5, 2010 at 2:02 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4R MGM TRDOR Premium Daddy Wagon
    glad everything works now. post some pics of the DTRL on
