Need help installing a 2013 oem touchscreen on a 2012 taco
Discussion in 'Audio & Video' started by galveznano, Apr 21, 2013.
  1. Apr 21, 2013 at 8:39 PM
    galveznano
    galveznano [OP] Active Member
    Leo
    Santa ana
    black prerunner
    procomp 2in lift, secondary air filter delete
    The plugs for the usb, steering wheel buttons and antenna are difrent, is there adapters to make this work or how could i wire it up to work ?
  2. Apr 23, 2013 at 9:57 AM
    Aw9d
    Aw9d That one guy
    Sounds like one is JBL and one isn't. Is that the case?
  3. Apr 23, 2013 at 10:00 AM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Why not just go aftermarket?
  4. Apr 23, 2013 at 10:01 AM
    BlackSeven
    BlackSeven Well-Known Member
    Maryland
    2017 4cyl 5 spd 4x4 extended cab
    Toytec Ultimate Lift kit, Toytec Rear AAL, 4.88 Gears, ARB Rear locker, Doug Thorley header, Volant Cold Air Intake, Demello Offroad front high clearance bumper, ARB On board Air compressor, BLHM, Wet Okoles, 2011 Color matched grill, Weathertech mats, 4x Innovations Sliders, ATO Engine Skid plate, ATO High lift bed mounts.
    I hate to use the "can't" word... so I'll say there are no plug and play methods of doing this. It would be easier for you to sell the OEM unit and purchase an aftermarket unit, as adapters at least exist for that purpose.
    Aside from that, my best advice is to start comparing wiring diagrams for the two units and get the wire plugs from a 2013 model truck.
  5. Apr 23, 2013 at 5:16 PM
    galveznano
    Leo
    Santa ana
    black prerunner
    Its a panasonic touchscreen only, no nav, i just called the stealer and they offer no help, rewire i guess. I wanted this one because i like the clean look of oem, but want oem+
  6. Apr 25, 2013 at 3:28 PM
    galveznano
    Leo
    Santa ana
    black prerunner
    I got the antenna adapter and now I have radio, touchscreen, usb, and cd player with mp3, just need to wait to figure out how to rewire the microphone and the steering controls
  7. Apr 25, 2013 at 3:51 PM
    Aw9d
    Aw9d That one guy
    Wait.. Your title is OEM2013 into a 2012 and now you are saying its a Panasonic touch screen? Very confusing and it makes it hard to help you out.
  8. Apr 25, 2013 at 7:57 PM
    galveznano
    Leo
    Santa ana
    black prerunner
    Wait what dude, ill make it more clear, i own a 2012 taco and i am installing a OEM 2013 taco touchscreen head unit. I got the antenna figured out power speakers ok, the usb charges my iphone but wont work for music, the steering controls dont work and the microphone for hands free is mia, i figure its part of the 2 connectors that are way diffrent. Btw the oem headunit is made by panasonic
  9. Apr 25, 2013 at 7:59 PM
    galveznano
    Leo
    Santa ana
    black prerunner
    My factory system is non jbl of that helps
  10. Apr 30, 2013 at 5:38 AM
    BlackSeven
    Maryland
    RE: Bluetooth, you might be able to get the Blu logic kit for a 2013 truck and adapt it to fit yours.
    Aside from that, you need to get the 2012/2013 wiring diagrams (or buy a subscription to TIS - https://techinfo.toyota.com) which will have all the diagrams you need.
  11. Apr 30, 2013 at 9:49 PM
    galveznano
    Leo
    Santa ana
    black prerunner
    Its just a matter of time before some one of you figure it out, ill be patient
  12. May 1, 2013 at 6:57 AM
    Speakerboy
    Speakerboy Well-Known Member
    Jim
    Center Valley, PA
    '02 Xtracab 5 lug manual
    USB has 4 wires, and it sounds as though you have 2 wires hooked up correctly (that would explain charge but no music through iphone). As far as your steering wheel controls, AS STATED, you need the wiring diagrams for both trucks to figure out which pin goes to which wire. I applaud your OEM+ upgrade, but there is no plug-n-play solution, and being the first to do something requires some ingenuity.
  13. May 1, 2013 at 5:27 PM
    galveznano
    Leo
    Santa ana
    black prerunner
    Yes speaker boy, im waiting for a junked 2013 to harvest the conectors and ill be good to go, im content with the function of it all for the time being, still working on the vibes from what i think is a bad cabin mount
  14. Jun 14, 2013 at 5:32 PM
    blktaco58
    blktaco58 Well-Known Member
    Hawaii
    2019 off road dc
    im in the same boat- what antenna adapter did u get to make it work?
  15. Jun 14, 2013 at 6:07 PM
    galveznano
    Leo
    Santa ana
    black prerunner
    I dont remember the part number but i got it at a rinky dink auto stereo store, the guy heard tacoma headunit and knew which one it was, i guess its a comon adapter for aftermarket radios cost about 15 bucks, it will have the hole where u plug ur antenna and a extra blue wire i believe, dont hook the other wire up or ur headunit wont come off with the ign off.
  16. Jun 14, 2013 at 6:09 PM
    blktaco58
    Hawaii
    2019 off road dc
    ok thanks
  17. Jun 14, 2013 at 6:10 PM
    blktaco58
    Hawaii
    2019 off road dc
    did you ever figure out the other stuff- like the usb and mic wiring?
  18. Jun 14, 2013 at 6:44 PM
    galveznano
    Leo
    Santa ana
    black prerunner
    Not yet, working on it, i hate wiring
  19. Jun 19, 2013 at 12:10 AM
    JayAre
    JayAre Well-Known Member
    OR
    13 TRD Sport DCLB
    Here's the mic wiring if it helps.
  20. Jun 19, 2013 at 12:41 PM
    blktaco58
    Hawaii
    2019 off road dc
    thanks- isn't the 2013 tacoma R15 harness have more pins that the diagrams above ^^^
    I know the 2012 plug is different and has less wires
