Need help installing bedside decal!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ultrabattler, Jan 30, 2016.
  1. Jan 30, 2016 at 5:31 PM
    ultrabattler
    ultrabattler [OP] Well-Known Member
    Denver, CO
    '15 TRD Offroad dlcb
    Fox 2.5 w/ resi. HS AAL Pack. Stickers for extra HP.
    Hey guys, I have a 2014 Tacoma dbcb shortbed. I have taken off the factory "TRD Sport" decal on the side of my bed and would like to install new decals.
    I am using painter's tape, a level, and measuring in from both sides to put it on.
    I am just wondering if anyone has any advice learned from experience, that I may not have thought of.
    Thanks guys :)
  2. Jan 30, 2016 at 5:36 PM
    VandalTaco
    VandalTaco Well-Known Member
    Will
    Moscow/Idaho falls, Idaho
    07 DCSB TRD SPORT
    OME 887 lift, 16" XD addicts, 285 duratracs, leather seats, badass JL/Focal stereo
    I just put them on carefully...I don't really know how to describe it. Just started by sticking one side and slowly working it through until the entire thing was stuck.
    This thread has a link in the last post for dimensions on decal placement...good luck!
    https://www.tacomaworld.com/threads/trd-decal-placement.167777/
  3. Jan 30, 2016 at 5:39 PM
    Howen
    Howen Well-Known Member
    2016 DCSB OR M/T black w/Leer 180
    I would use blue painters tape to make a line below, and a level.
    DrFunker likes this.
  4. Jan 30, 2016 at 5:41 PM
    ultrabattler
    Denver, CO
    yeah, that is what I'm doing. painter's tape, level, and measure in from each side. Just curious if there are any suggestions from experience, I may not have thought through
  5. Jan 30, 2016 at 5:57 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    I wouldn't use a level.
    I'd go with the lines of the body and go parallel from that using measuring tape and masking tape as your new line to decal to.
    TnuggetTaco, DrFunker and Fitz235 like this.
  6. Jan 30, 2016 at 6:22 PM
    ultrabattler
    Denver, CO
    Thats a good point, cause from the pdf attached above, it seems the sticker is not level based on the measurements.
  7. Jan 30, 2016 at 6:26 PM
    1R0NMAN811
    1R0NMAN811 Well-Known Member
    Sneads Ferry, NC
    2015 Tacoma DCSB TRD OR
    If you mix some soap and water into a mild solution in a spray bottle and spray it on the sticky side and paint before you put them on it will help. Will be able to slide it around a little for adjustments and makes getting any bubbles out easier.
  8. Jan 30, 2016 at 6:32 PM
    File IFR
    Central MA
    With larger decals, sign guys that letter commercial trucks use magnets to hold the decal in place before peeling the backing off.
    The bedside decal wouldn't require magnets.... it's not that big.
  9. Jan 31, 2016 at 1:43 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    Remember ... folks can only see one side at a time ... do they have to be exact ... not really .... a little dish soap in a spray bottle of water ... you can move it about somewhat.
    bigfoote13 likes this.
  10. Jan 31, 2016 at 1:52 PM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    all of the above, no level, just measure. AND a hard plastic squegee thing, or a credit card, it will help get the bubbles out. go slow and measure three times, this is what i did, came out great.
  11. Jan 31, 2016 at 6:44 PM
    Kyle01
    Kyle01 Well-Known Member
    Kyle
    Chicago
    2024 TRD Offroad double cab 6MT
    Better idea- leave them off. Haha, just my opinion. I hate the dumb "Totally Rad Dude" stickers on the bed sides.
  12. Jan 31, 2016 at 6:47 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    A level only makes sense if the truck is on a perfectly level surface
  13. Feb 1, 2016 at 2:38 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    Just to add to what's already been suggested, I would probably use the plastic cap thingy on top of the rear fenders a reference point for measuring. It's a straight line on top of the fender, that runs the length of the bed. The problem with using a level, even on level ground, is that the truck is likely not level. Especially if it has any kind of rake to it, or "Bro Lean".
    Also take this from someone who hasn't done this, but has done tons of other applications, I don't know what the backing is like, sometimes it's split in half, sometimes not. But in either case, What I usually do is get it lined up, and peel the very edge of the backing off (for that decal, maybe an inch of it), fold it flat back on itself (the backing), with it still lined up, stick that small piece on, check to see that your still where you want to be (that way if not, you can adjust), and if so, start to peel the backing, and flatten as you go. If you do it this way (assuming it's a heavy vinyl, which are usually very forgiving), it should go on with little, to no bubbles to flatten out. As has been mentioned before use a credit card, and flatten as you go. Meaning as you are peeling the backing, flatten the bubbles. It will probably help to do this with a light held to the side of the truck while looking down the side. This will highlight any bubbles.
