Need help installing Bosch Icon wiper blades
Discussion in '2nd Gen. Tacomas (2005-2015)' started by scully, Nov 28, 2010.
  1. Nov 28, 2010 at 3:12 PM
    scully
    scully [OP] Well-Known Member
    San Diego, CA
    06 TRD Doublecab
    Rear TSB FJ Cruiser TRD anthracite wheels Bilstein 5100's allround Tint
    Was able to get old rubber inserts out, but can't figure out how to install these icons? Any advice would be appreciated.
  2. Nov 28, 2010 at 3:15 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Are you replacing the entire blade or just the insert?
    I found them much easier to install than normal blades. I think there are instructions right on the box. If you squeeze the center (where it says Bosch), they should open up and slide right on. Then you clamp it back down.
    Good luck.
  3. Nov 28, 2010 at 3:49 PM
    scully
    San Diego, CA
    06 TRD Doublecab
    looks like the design replaces the entire blade but still can't figure it out??
  4. Nov 28, 2010 at 3:52 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    They do replace the entire blade. Like the other guy said, where the blades say "Bosch" there is a plastic piece that flips up and they'll install the same way any other blade will to the metal wiper arm.
  5. Nov 28, 2010 at 4:24 PM
    scully
    San Diego, CA
    06 TRD Doublecab
    Makes sense but how do you remove the OEM blade from the wiper arm? All I was able to remove were the "wiper inserts".
  6. Nov 28, 2010 at 4:39 PM
    Pugga
    Massachusetts
    The wiper arm is metal and shaped like a shepards crook at the end where the blade connects. The open part is toward the wiper arm so when you pull the blade away from the windshield, move the windshield wiper blade so it's perpendicular to the arm (so it's like a T) then push the blade towards the wiper arm. It should come apart. Then install the new blades in the oppositte order.
    http://www.youtube.com/watch?v=051hkkgnrGY
    There you go, try to pay attention to the procedure, not the girl...
    ready6delta likes this.
  7. Nov 28, 2010 at 4:40 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    There is a tab you have to press to release the wiper.
  8. Nov 28, 2010 at 8:36 PM
    scully
    San Diego, CA
    06 TRD Doublecab
    Thanks guys, was able to get them off, now I just need to figure out how the new ones slide on. That girl makes it look wayyyy to easy!
  9. Nov 28, 2010 at 9:17 PM
    Taco11
    Taco11 Well-Known Member
    Seattle WA
  10. Nov 28, 2010 at 9:20 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    god that girl is hot, and it is that esay
  11. Nov 29, 2010 at 4:32 PM
    scully
    San Diego, CA
    06 TRD Doublecab
    Purchased the wrong part. Got the right ones and they slid right on. Great looking wiper and looking forward to lots of snow this year.
  12. Nov 29, 2010 at 4:43 PM
    Pugga
    Massachusetts
    Maybe I should have used a different video... I'm guessing no one was actually watching the procedure...:cool:
  13. Nov 29, 2010 at 4:48 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    Wrong
    I was thinking of all kinds of procedures
  14. Nov 29, 2010 at 7:09 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    turn in your man card.
  15. Nov 29, 2010 at 7:15 PM
    28Gauge
    28Gauge Well-Known Member
    Brian
    Grapevine, TX
    06 PreRunner SR5
    Sockmonkey Graphics, K&N Drop In Air Filter, 265/75/16 Bridgestone Dueler A/T's, Weathertech Digital Fit Floor Mats, Dee Zee Bed Mat, Map Light/Dome Light LED's, Flo-Pro Muffler w/Stainless Steel Tip, Dome Light/Map Light Mod, Mobil 1 Synthetic Motor Oil, LED Cupholder Mod, Grillcraft with TOYOTA emblem, Vision 375 Warrior Wheels, Extra Bed D Ring Mod, TRD Skidplate, Bilstein 5100's on all four corners, Front 5100's set at zero with Eibach springs, Toytec 1.5" rear TSB add-a-leaf springs, Toytec swaybar relocate kit, Katzkin Leather Seating, Front Window Tint
    I need to replace my wiper blades, too. Are the Bosch blades better than OEM?
