Need help installing keyless entry
Discussion in '1st Gen. Tacomas (1995-2004)' started by elicitone, Oct 25, 2011.
  1. Oct 25, 2011 at 7:10 PM
    elicitone
    elicitone [OP] Well-Known Member
    Ontario
    So I picked up a cheap keyless entry system off EBay. I know why it was cheap now. No install instruction s came with it. WTF?
    So I trial and error'd it and thought I had it all working, that is until I clossed the door.. Unit works perfect when i have the doors open but stops functioning as soon as they're closed?
    Any body have a though as to what I may have done wrong?
    I have hooked up: Positive + Negative at the Ign switch. Parking lights at the back of the fuse box Green wire in 12 pin connector. Then lock and unlock (grey + purple) from the 22 pin connector at the fuse box and then trigger on the green wire.
