Need help installing Pioneer Headunit!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dataco09, Mar 14, 2022.
  1. Mar 14, 2022 at 10:13 PM
    dataco09
    dataco09 [OP] New Member
    2010 access cab 6 sp manual w/ sr5
    Ughhh!!!! I’m about to pull my hair out because I wired everything up and I have no power. I rewired the stock radio and that works fine so know I might be a compatibility issue? There are 4 plugs on the stock radio (1 for the speakers, 1 for steering wheel, 1 for power and other speakers, idk what the other is for). I took photos so you guys have a reference point.
    bottom line: I’m trying to install a Pioneer DMH160 BT using metro harness. I wired stuff up and no power. I need help!
  2. Mar 14, 2022 at 10:28 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Go here: https://www.crutchfield.com/S-E644TY6yayY/car/carselector.aspx
    And find the harness adapters needed to directly plug into the stereo and your truck.
    They also have excellent technical assistance.
    Here is what they show for a 2010 Access Cab: https://www.crutchfield.com/g_103000/Wiring-Harnesses.html
    For the steering wheel controls it looks like this is what you want: https://www.crutchfield.com/p_249TY61S/Crux-SWRTY-61S-Wiring-Interface.html?tp=2977
    I know it seems pricey, but it is hard to keep trying to hard wire a stereo as you are doing and then accidently burn something up that cost even more.
  3. Mar 14, 2022 at 10:54 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    This. Do it right and you only do it once, plus you won't be having to cut and splice off the factory harness. I used the harness @Jimmyh posted and 9 years later zero issues. I don't have wheel controls so can't speak to that.
    TnShooter likes this.
  4. Mar 14, 2022 at 10:58 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I agree with @Jimmyh. Spend the money and plug it in.
    It will be worth it.:thumbsup:
    However, it would help if you told us what system you have JBL or Non-JBL?
    My opinion is not worth much, but those scotch lock splices are usually a headache later on.
    Charlie Bravo, Toy4me and Jimmyh like this.
  5. Mar 14, 2022 at 11:04 PM
    TRP
    TRP Well-Known Member
    Do you have a test light? Those wire splice connectiors are not the best.
    Test 12v constant, 12v switched, and ground. It's super basic. My guess is one of your connections is bad.
    ZMan2k2 likes this.
  6. Mar 14, 2022 at 11:16 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Likely one of the splice connectors isn’t seated well, I’m betting the ground (black) or red (can’t see how that’s connected) since yellow looks good. I had that happen to me as well, they are just not the easiest to get right. I would use butt connectors instead. Red to red, yellow to yellow, black to black and it should power up.
    It’s not rocket science but it is nice to have a clean adapter harness without bulky splices or butt connectors. I used to solder mine but now that I have all the oem connectors I just crimp direct. I imagine the crutchfield ones are pretty nice but haven’t ever bought one other than metra pigtails. Which, now that I know more about the OEM connectors, no longer feel nice enough to me.
    Solvable problem, just take your time.
    Btcomcast likes this.
  7. Mar 15, 2022 at 3:42 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Like others have pointed out, those wire connectors are the issue. I can guarantee you that its a faulty connection and can easily be checked simply probing with a test light. Personally, replace those with butt connectors. The ones being used are a horrible choice and tends to be erratic in its connections, making diagnosing issues more time consuming. I totally agree with calling and buying the harnesses through Crutchfield.
  8. Mar 15, 2022 at 4:13 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C’d DCLB TRD SPORT
    Could be the way the harness is connected using those connectors.
  9. Mar 15, 2022 at 5:49 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    ‘Berta
    06 Rad Red DCLB SR5, ‘25 SS Red Sport Prem. (on order)
    This is where to start. I’ve spliced in head units before using scotch locks. Usually, with your problem, one of those 3 is the issue. A DMM or a test light will set things straight.
    And I agree on the Metra adapters. $20 well spent. Currently using one on my truck. 16 years and no problems.
  10. Mar 15, 2022 at 6:35 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    As noted, get rid of those splice taps and get the proper plug and play harness!
  11. Mar 15, 2022 at 7:59 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    And another vote for this as long as you haven't chopped up your factory harness. While you're in your garage, grab that box of splices and toss them in the trash and you'll be much happier in the future.
    Charlie Bravo and TnShooter like this.
  12. Mar 15, 2022 at 11:06 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    The problem here is that the connecting wires are so small of a gauge that when crimped with those type of connectors, the only thing that's crimped is the insulating sleeve. You are better off going the old school route of manually twisting the wires together and wrapping with electrical tape.
  13. Mar 15, 2022 at 11:06 AM
    vorkuta775
    vorkuta775 Well-Known Member
    Texas
    tesla truck
    @elduder help ?
    elduder likes this.
  14. Mar 15, 2022 at 11:29 AM
    ABA180
    East Bridgewater MA
    This, I've been a fan of heat shrink tubing as well. I've swapped my head unit out twice in my truck but the harness has been installed since 2012 and I have yet to have a single problem with the connections.
  15. Mar 15, 2022 at 11:29 AM
    TegoTaco
    Ontario, Canada
    Better yet, heat shrink. :)
  16. Mar 15, 2022 at 11:38 AM
    ABA180
    East Bridgewater MA
    Great minds homie :)
    TegoTaco[QUOTED] likes this.
  17. Mar 15, 2022 at 1:06 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Welcome to TW. :hattip:
    :smack: for using those scotch lock bs splices.
    Go buy some red butt splices and a real crimp tool from home cheapo.
    Then, pay attention... There's info for the harness adapter. Info for the radio wires. 20 minutes and it'll be clean, without those ends sticking out and shorting out.
    Good luck.:drunk:lol
  18. Mar 15, 2022 at 4:29 PM
    Charlie Bravo
    Charlie Bravo Well-Known Member
    Charlie
    Coeur d'Alene, Idaho
    2009 Red Tacoma Access Cab 4wd 2.7MT
    RedLine Tuning hood QuickLIFT, Gen3 alloy 16x7J, All Pro Off-road bed stiffeners & IFS skid plate
    I've been reading all the threads on replacing radios, looking at Crutchfield (great products, esp. the Posi-Twist and Posi-Tap connecters that look much better than the ScotchLok taps, which looked dubious when we first saw them back in the late 1970s or whenever they first appeared). I was surprised to find Scotchloks at the auto parts store, and so was one of the OGs that I held the door open for as he was going back in to work. I asked and he managed to find a 7-pack, while I was glad I found a 25-pack to replace the old ones with as I was tasked with replacing the old aged interior light fixtures on a Dodge Sportsman Mini-Winnie with new LED lights. Mission accomplished as the folks it was donated to sold it to a happy new owner.
    When it's time, I'll drive over to Aspen Sound or someplace to get the non-JBL radio replaced. Since some things have become more complicated, I'm more than willing to hire practiced assistance on those items. Before it turns into :ballchain:.
  19. Mar 15, 2022 at 6:18 PM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    @dataco09
    Do you have a voltmeter?
    It's been a while and I dont frequent here as much. If I remember correctly though the OE side 12v wires should be the blue/yellow and grey wires.
  20. Mar 15, 2022 at 9:14 PM
    Bajatacoma
    SC
    I've also had good luck with the heat shrink butt connectors with the solder in the middle and adhesive in them (the marine grade).
    Charlie Bravo likes this.
