NEED HELP LONG CRANK TO START
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yotatoy, Mar 16, 2011.
  1. Mar 16, 2011 at 6:00 PM
    yotatoy
    yotatoy [OP] Well-Known Member
    il
    2010 Toyota TRD 4x4 4D V6
    Avid side steps Nokia Yellow fog lights t-rex eyelids trd sport hood front windows tint
    What i have is a 2010 trd off v6 d cab. I got the truck last feb, since then i only put 4,000 miles on it. but one time last year and one time last week and today. i went to start the truck and it was cranking forevery. now it does start on the first long turn or the second turn, (its like no gas and then i bit then runs rough) it runs rough for 2 sec then idles great. i drop it off at toyota dealer today and told them keep it for a week and they gave me a camry to drive. any one have this problem as well, i always use a name brand gas pump, and no other problems. any info or items to check will help thanks
    only thing installed is a oem trd oil cap and recall gas pedal done (all stock)
  2. Mar 16, 2011 at 6:40 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    There was a TSB for earlier Second gens for this issue. The ECU needed reflashed to fix it.
  3. Mar 16, 2011 at 6:43 PM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    yeah i have the same problem but im out of warranty so no tsb for but it cranks for a while 1st try then always catches second time but this only happens once in awhile
  4. Mar 16, 2011 at 6:48 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    I just started a thread on this today. I've only had mine 5 weeks and it did it several days ago and then today it did it again. Has me worried. Someone said I need to let the fuel pump prime first? WTF? It's a brand new truck. :(
  5. Mar 16, 2011 at 6:50 PM
    rme
    rme Well-Known Member
    Savannah
    Green TACOMA
    XM, Panasonic Stereo, Headlights,Electric Ant,Toyota Deluxe Wheels, Rhino Lining, Cargo Rails
    I had a BMW that had this problem and it was a couple of injectors that were bad. After I paid to have the computer test it I realized I could replace all six of them for 50 bucks more than replacing two of the bad injectors plus the test....I got a kiss for that one....
  6. Mar 16, 2011 at 7:25 PM
    Zoot
    Zoot Well-Known Member
    2011 DC/SB TRD O/R 4X4
    Toyota bed mat, Wet Okole's F&R, Window Tint, custom trail-stripes, Cooper A/T3 265/75R16, MedlinAround interior LEDs, Leer 100r, aFe air filter, K&n cabin filter
    Ya mine did it the other day when I was on "E" and I was angled down hill.. just figured it was normal per the circumstances.. i'll let u know if it does it again tho
  7. Mar 18, 2011 at 4:58 AM
    HuntnTruk
    HuntnTruk Tacohead
    Kevin
    New York-not the City
    Indigo SR5 4x4
    Mine did it for the first time this morning. It might have been because I was low on gas but I havent had this happen with any other vehicle.
    I just want consistency. It seems everytime I drive this truck there is something else. Makes me think about how much I am spending in suspension and wheels.
  8. Mar 18, 2011 at 5:47 AM
    ecoterragaia
    ecoterragaia Well-Known Member
    Mid-Atlantic
    '06 RC, 4X4, 5 speed
    I've had my truck for about 2 months now, daily driven, and this has happened on the three of four occasions that I've stalled taking off at a stoplight. It stalls, I turn the ignition to off, turn the key to on, then crank the engine for a few seconds and it won't start. I have to turn the ignition to off again, then crank it over again before it finally catches. This takes what seems like forever when you're already embarrassed about stalling it out in the first place and the people behind you are making angry faces.
    I've never had a vehicle do this, and I've owned three manual trans. cars before. Kind of weird, but since it doesn't occur on a normal basis (just when I stall it out), i haven't been worried about it. Still getting used to the various clutch uptake levels and the odd/vague throttle modulation on this truck though.
  9. Mar 18, 2011 at 5:06 PM
    judd94
    judd94 Well-Known Member
    Ponchatoula, LA
    17 4Runner TRD Off Road Premium
    Mods in Progress
    I have noticed somethin similar in my new and old tacos. i notice it only happens in spring or fall when you have winter gas on a warm/hot day or summer gas on a cold day.
    OP- this might just be a little more exacerbated since it sounds like you don't run your truck often. If it does it repeatedly then you probably have a problem
    Does ethanol go "bad" quicker than real gas?
  10. Mar 24, 2011 at 10:19 AM
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
    i have had this happen to me on occasion, particularly when it is cold out, just a delayed start however, not much to cause worry, just a mental note. mine is an 08 and if it gets any worse or more persistent i just might have to check out that tsb
  11. Mar 24, 2011 at 11:26 AM
    rme
    Savannah
    Green TACOMA
    YEs ethanol does not last in quality as long as "real gas!" Both of my lawnmowers and the service dept agree with that statement....
  12. Mar 24, 2011 at 2:54 PM
    KevLot17
    KevLot17 Well-Known Member
    Kevin
    Pennsylvania
    '10 Blacked Out TRD Sport
    Debadged, Toytec Ultimate Lift, Banks Monster Exhaust, AFE Pro Dry filter, Black Grillecraft grille, Flat Black background headlights, Red Blinkers and markers with alternating turn signal mod, Krypton Bulbs 6000K Headlights and Fogs, Fog Light anytime Mod, LED interior lights with map light mod, AVS Black Taillight Covers, Tinted Windows, WeatherTech Digital floor liners.
    I just had my pressure washer replaced(bough new last april and brought it in in November..JUST got replaced last week). And in October i had to rip apart my quad and clean the caburator. I Talked to a service tech from a Honda dealer, he said there has been numerous problems last summer w. the same issue.. The ethanol breaks down and leave small white deposits(almost like little bb's) they eventually cause everything to clog up and run like shit or not at all. this process can happen in as little as 2 weeks!. for the small engines, run no less than 93 with a few ounces of Sta-Bil Ethanol Treatment.
    As for our trucks.. mine does the 'Long Crank' every now and then. Yesterday was the worst, thought maybe cause it was 60 degrees this weekend and then we got 8" of snow yesterday. But our trucks are manufacture to run with ethanol... but if this is a problem.. whats gonna happen when the new law goes into effect using 15% Ethanol rather than 10%?
