Need Help- Marker lights not working
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Flash1034, Aug 13, 2018.
  1. Aug 13, 2018 at 6:12 PM
    Flash1034
    Flash1034 [OP] Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    I went to replace my marker light bulbs with LEDs. They were working then suddenly both went out. I figured a fuse but I can’t find a burn out fuse and am not sure which fuse controls the marker lights. Everything else seems to be working. I plugged the original bulbs in and there is no power to either marker light.
    Anyone know which fuse controls them? Any other ideas?
    Thanks
  2. Aug 13, 2018 at 8:11 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Check then all. In engine bay and under dash. Check wiring diagram to find the proper one, and look real close at it. Burned out doesn’t always look burnt out.
  3. Aug 13, 2018 at 8:49 PM
    Flash1034
    N/W Montana
    Thanks. I found it...was the taillight fuse under the dash. Why, O, why doesn’t the owners manual have a fuse location breakdown?
    Thanks for the help.
  4. Aug 13, 2018 at 9:01 PM
    jmauvais
    NorCal
    ...stuff
    Because the covers to the fuse boxes have the diagram inside?
  5. Aug 13, 2018 at 9:22 PM
    Flash1034
    N/W Montana
    It does...if you can decipher it...
