Need help mounting bumper in Tucson
Discussion in 'Arizona' started by Infra, Feb 19, 2013.
  1. Feb 25, 2013 at 12:50 PM
    GTABurnout
    GTABurnout Well-Known Member
    Tucson AZ
    2012 Tundra Crewmax Rock Warrior TRD SC
    Icons, TRD Supercharger, TRD Exhaust, TRD Intake
    Looks great. How I missed this tread till do day I don't know.
  2. Feb 25, 2013 at 3:03 PM
    JeepAndrew
    JeepAndrew Mexican Bearded Firequeefs everywhere!
    Andrew
    Tucson, AZ
    "2" many Modded Heeps
    Lots-o-mods
    Hmm... There may be a way to mount that can carrier right on the swing-out so it's not in the way..
  3. Feb 25, 2013 at 3:31 PM
    Infra
    Infra [OP] Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    Yeah Andrew the can carrier mounted in my bed is not the same one that mounts onto the swing away. The one that came with the bumper does mount right onto the swing away, and when mounted onto the swing away it makes my truck 3/4" too long to park in my garage....and I am required to park in my garage due to my homeowners association. It's ok...I really don't like the look with the can carrier mounted on the swing away so.....I'll only mount it when I go on wheeling/camping/road trips. No biggie :D
  4. Feb 25, 2013 at 4:21 PM
    JeepAndrew
    Andrew
    Tucson, AZ
    Lots-o-mods
    That works! The fab gears were turning so I thought I'd chime in :D Don't get me started on HOAs though... :censored:
  5. Feb 25, 2013 at 9:10 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Just gotta say... Fuck HOA's :cool:
  6. Feb 26, 2013 at 7:01 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Damn Jason....that bumper looks beastly!
  7. Feb 26, 2013 at 7:52 AM
    Infra
    Az
    So now I have a little bit of a bro lean going on. Rear is sagging about a 1/2" lower than the front. I have dakar leafs in the rear so not sure what to do other than throwing in 1" blocks in the rear.
    Suggestions anyone?
  8. Feb 26, 2013 at 8:07 AM
    snowtank
    snowtank Where the fuck did my beer go!
    Andrew
    Arizona
    11 txpro dcsb 08 trd sprt dcsb
    Some stuff here and there....
    Would refurbishing your leafs give you the half inch back?
  9. Feb 26, 2013 at 8:30 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    What are you running in the front? Any adjustment there?
  10. Feb 26, 2013 at 8:38 AM
    Infra
    Az
    Yes I am running a Toytec Ultimate lift, I can turn them down but will have even more rubbing issues than I am having now.
  11. Feb 26, 2013 at 10:54 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Trimming is the best way to eliminate rubbing! Pinch weld, cab mount and lots o' lots of plastic!
  12. Feb 26, 2013 at 10:58 AM
    Infra
    Az
    Yeah I've done plenty of trimming on the front as well as having a CMC, but still have minor rubbing issues. There is no way I would turn down the CO's to match the rear. I am thinking I will just have to throw a 1" block on the rear.
  13. Feb 26, 2013 at 11:13 AM
    JeepAndrew
    Andrew
    Tucson, AZ
    Lots-o-mods
    Amen! :D
  14. Feb 26, 2013 at 8:53 PM
    b4iceman
    b4iceman Well-Known Member
    James
    Chandler, AZ
    '10 Tacoma 4x4 TRD Off Road
    Nice bumper!
  15. Mar 8, 2013 at 1:37 PM
    #35
    mh.meier
    mh.meier PB MIKE Vendor
    MAD MIKE
    Flagstaff AZ
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front 3-hoop bumper(soon to be single hoop CM) -Rigid 20" SR series light bar -Rigid Dually D2 Flood pods -KM FABRICATION custom 1/4" steel bumper mounts -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB 6' Awning -KMFAB bed reinforcement -AVID Offroad weld on slider -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -Icons Ext Travel front CO's -King 700# coils -Camburg Uni-ball UCA's -Sway-A-Way 2.0 rear shocks -All-pro Expo LEaf packs w/ custom bumps -35" Goodyear Wrangler MTR's w/ Kevlar -16" SCS SR8's in Black -Custom Retrofits -Smoked Tails -Flare-less mod -AFE ProForce Magnum CAI (went back to stock) -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    Do the blocks Jason, they wont make much difference other than lift. I have the expos so I didnt have to worry about that, I have to raise my front instead haha!
  16. Mar 18, 2013 at 4:47 AM
    #36
    cytocycle
    cytocycle Well-Known Member
    Scottsdale, Arizona
    Expedition Build - 2012 TRD Off-Road
    ARB Front Bumper with fogs, TJM 9,000 synthetic rope winch with Pro-Link, AllPro Bolt on Sliders with fill plates, Asfir Aluminum Front Skid, Mid Skid, Gas Skid, Transfer Skid, AllPro Shackle flip kit with Timbern, CBI HC rear Bumper, Rigid Mesh Grill with 20" LED bar, White Sport Grill Opening, ARB Dual Compressors and 2 gallons of air tanks for air tools, Dakar Leaf Pack, RadFlow 2.5" Extended travel Coilovers- front & rear shocks with res, front sway bar delete, Camburg UCA's, Stainless Steel Brake Lines on all wheels fixed mushy brakes, UltraGuage
    If you are running Dakar's you can add an overload leaf to them as it's supported for extra weight which is why I went with them, when I add a camper and gear. Talk to Sierra Expeditions in town
  17. Mar 18, 2013 at 7:56 PM
    #37
    Infra
    Az
    Thanks for the info
