Need Help..my 19 Taco won't start
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 19_taco, Aug 22, 2020.
  1. Aug 22, 2020 at 11:08 AM
    19_taco
    19_taco [OP] Member
    Ricky
    2019 Magnetic Grey TRD Sport
    I have a 2019 DCSB Sport. I have the N2 remote start system, and push button ignition. Everything has worked flawlessly up until 5 mins ago. I did some running around this morning and had no issues. I was trying to go get some lunch and my truck won't start.
    I get in, everything works, push brake pedal hit start button, no start, radio lights and all accessories work fine.
    I can turn off the truck and remote start with the key fob, truck starts fine. I went through the troubleshooting in the manual, still no go..
    Any ideas??
  2. Aug 22, 2020 at 11:09 AM
    Bishop84
    Bishop84 Well-Known Member
    Try holding remote against the start button.
    BalutTaco likes this.
  3. Aug 22, 2020 at 11:12 AM
    19_taco
    19_taco [OP] Member
    Ricky
    Still nothing
  4. Aug 22, 2020 at 11:13 AM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    are you park on a flat surface?
  5. Aug 22, 2020 at 11:16 AM
    UAL777jet
    UAL777jet Well-Known Member
    Bill
    Norwalk, IA
    2019 Tacoma TRD Pro Voodoo Blue
    TRD Performance Air Intake
    Put it in neutral and try it.
  6. Aug 22, 2020 at 11:18 AM
    19_taco
    19_taco [OP] Member
    Ricky
    Yes
  7. Aug 22, 2020 at 11:18 AM
    Dc2tacoma
    Dc2tacoma Well-Known Member
    Thanks for calling tech support. Have you turn it off then back on?
    disconnect the battery from the truck for 15 min and then reconnect. See if that helps.
  8. Aug 22, 2020 at 11:18 AM
    19_taco
    19_taco [OP] Member
    Ricky
    Still nothing
  9. Aug 22, 2020 at 11:22 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    After market ?? If dealer installed call the dealer or the shop that put it in . Or sell it to carvana lol
    tcjacado and Panchovilla6192002 like this.
  10. Aug 22, 2020 at 11:25 AM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    You can remote start it but the button is not working? Seems like the push button is broken. Have you installed any mods to the button or removed it?
  11. Aug 22, 2020 at 11:49 AM
    19_taco
    19_taco [OP] Member
    Ricky
    Yes I can remote start, but not normal start it.
  12. Aug 22, 2020 at 11:53 AM
    OMGitsme
    Sold
    Check the fuse for the button. I think it's a 7.5. I also think if your remote battery is dead the button won't work. I'd replace that first.
  13. Aug 22, 2020 at 3:03 PM
    Bishop84
    If the fob battery dies, place the key against the start button. It works as a back up.
  14. Aug 22, 2020 at 3:33 PM
    Kairide
    Kairide Well-Known Member
    2020 White SR5
    Unplug it, wait 30 seconds and plug it back in.
  15. Aug 22, 2020 at 3:36 PM
    19_taco
    19_taco [OP] Member
    Ricky
    So, I removed the N2 remote start module and it works.
  16. Aug 22, 2020 at 7:56 PM
    OMGitsme
    Sold
    Hmm, N2 has flawless CS. I'd give them a shout.
  17. Aug 23, 2020 at 6:24 AM
    19_taco
    19_taco [OP] Member
    Ricky
    I'll reach out to them. Although, I found that I didn't use the remote starter as much as I thought I would. And at this point I'd hate to replace it and get stranded somewhere I don't have the tools to remove it again. A wise man, (GWB) once said "Fool me once, shame on you..fool me twice.... you're not gonna fool me again".
  18. Aug 23, 2020 at 6:28 AM
    Timetraveler66
    Timetraveler66 Well-Known Member
    The chances of a new module doing the same thing is so slim I would see if they will replace the module. To just pull it all out is foolish. Unless you need to pay for it then I get it.
  19. Aug 23, 2020 at 4:46 PM
    19_taco
    19_taco [OP] Member
    Ricky
    I'm going to reach out to them. I understand the chances of getting a bum module twice is slim. And I guess carrying a Phillips screwdriver and a 10mm driver isn't too much to ask, but a headache is a headache.
  20. Aug 23, 2020 at 4:53 PM
    Georgia Native
    Georgia Native Well-Known Member
    4x4 DCLB 2017 SR5, 2019 4runner Offroad, 2021 SR Access Cab
    davidstacoma likes this.
