NEED HELP!!!! My Tacos Drinking gas like crazy
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fireman610, Mar 31, 2011.
  1. Mar 31, 2011 at 3:53 PM
    Fireman610
    Fireman610 [OP] Well-Known Member
    Evansville IN
    07 TRD DoubleCab 4x4
    Well shit I shoulda stuck w Chevy then my 02 crew 4x4 s10 w 120k on it would get 320 to a tank of gas w a 18 gal tank damn did I screw up buying this thing
  2. Mar 31, 2011 at 4:22 PM
    Fireman610
    Evansville IN
    Thats the thing It is stock only mod done to it is a set if NFAB bars and I also bought it for its reliability and dependability but 12 mi to gal on a stock truck says neither of the two I dont have any armor no oversized tires none of that. And yes I did buy it partially on its reputation for good gas milage for a truck its size I wasnt expecting hybrid milage but I also wasnt expecting 87 ford bronco milage out of it either
  3. Mar 31, 2011 at 4:38 PM
    o5iiawah
    o5iiawah Well-Known Member
    Tim
    Philly 'burbs, PA
    '11 4x2 access cab 2.7l
    450 miles per tank easy with my 4-banger :D
  4. Mar 31, 2011 at 4:41 PM
    LostRebel
    LostRebel Well-Known Member
    Almost Canada, USA
    Black Access Cab 4x4 TRD Off Road
    Fisher plow, BakFlip and Snugtop cap, Demello Sliders, Scanguage,
    What is your calculated mpg (miles per gallon)? The method you are using to estimate your fuel consumption is miles per tank, and may not be as accurate or easy to compare as miles per gallon.
    You can (if you want more accurate and comparable figures) track the miles that you travel and the gallons of gas that you use to travel those miles. Dividing the mileage by the gallons used results in your MPG (miles per gallon) figure. If this number is low over several tanks of gas, as compared to the mpg rates achieved by others and published by Toyota, you have a complaint. Until then, you might only have bad estimates of your gas consumption.
    I don't mean to dispute or discredit your present mileage estimates - I just think there is a more accurate method available to make the determination.
    Also: Have you compared your odometer to a GPS reading? A faulty speedometer/odometer can skew your mpg calculations.
  5. Mar 31, 2011 at 4:56 PM
    pmo
    pmo Well-Known Member
    Nova Scotia Canada
    2007 Tacoma 4x4, DC, 6 Speed Manual.
    21 MPG consistantly....octane makes no difference in fuel economy...dont switch to synthetic if your using real oil...synthetics with loosen up any deposits created by oil..may cause more problems..
  6. Mar 31, 2011 at 5:14 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    Is that 21 canadian or US gallon?
  7. Mar 31, 2011 at 5:19 PM
    deeznutz
    deeznutz Well-Known Member
    Seattle, WA
    09 SR5 DC LB 4x4
    I'm in the same boat as you. I'd be lucky to get near 300 miles.
    I'm only at 18K miles and I use premium gas and synthetic oil.
    Only mod are bigger tires 265/75/16 and a canopy in the back. I avg about 60mph on the highway, so not too fast at all. Plus I don't do those crazy jack rabbit starts at the lights.
  8. Mar 31, 2011 at 5:21 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    x2
  9. Mar 31, 2011 at 5:27 PM
    Leggo
    Newton,Ma.
    I am getting 20 mpg average now that the snow is gone. I drive mostly around town with a little highway now and then. Stock everything.
  10. Mar 31, 2011 at 5:30 PM
    98tacoma27
    Ben
    Not Beech Creek
    Maybe true / is not true
  11. Mar 31, 2011 at 5:37 PM
    showmeballer
    showmeballer Well-Known Member
    st. louis
    08 trd off-road
    None yet
    If you are calculating this correctly and getting 12mpg then something is Seriously wrong.
    Next time you fill up, zero the odo, run it until the gas light comes on and then divide miles by gallons. If you are still under 16, then take that mofo to the dealer and have them sort it out.
  12. Mar 31, 2011 at 5:53 PM
    nick
    nick MURDERED_TACO
    Green mountain ,nc
    - 2003 trd
    x2---- or maybe your fuel filter.......?
  13. Mar 31, 2011 at 5:54 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    I just drove a 2007 mega cab and it got better then 12 mpg.......not a chance its running right
  14. Mar 31, 2011 at 6:03 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Ever since the cold weather started (Ohio), my gas mileage has gone down the shitter and I'm a 4 Banger. I had to switch up to premium to get any sense of something reasonable in MPGs.
    I did the same thing..."WTF is up w/ my truck!!!" and I figured if something was truly wrong, my truck would let me know by a light or something.
    So...the cold weather, kills your damn gas mileage.
    All the proof I need? When we did have a warm week here in Ohio recently, my gas mileage magically improved quite dramatically. You got your truck in Jan, so you have no warm weather to compare it to and your in Indy.
    During the cold, cold months, I was damn lucky if my gas needle didn't start to move past the top F dash in under 40 miles....during that warm week, same quality gas, no different driving, more than 55 miles at the same point on the fuel gauge.
    It's nuts. I am more pissed off about the cold weather because it kills my MPGs than anything.
    Still love my truck.
  15. Mar 31, 2011 at 6:04 PM
    #35
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    I only get 14-16 city and 18-20 highway. I've never seen 18 city even when I had my stock tires and my mpg's have gone down a bit with the beefier Duratracs on there.
  16. Mar 31, 2011 at 6:06 PM
    #36
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    false... winter gas is a different mixture of gas that is less efficient.
  17. Mar 31, 2011 at 6:08 PM
    #37
    jking3002
    jking3002 Well-Known Member
    Jonathan
    Kentucky
    Scion tC
    Ricer muffler, window tent, trd shift knob.
    If you're letting it run down until right when the E light comes on, you're running it down to 4 gals left according to a study done here on TW. With a 21 gallon tank, that means you're using 17 gals. This means you are getting between 13.5 and 15.2 MPG. This is between .8 and 2.5 MPGs under it's rated numbers of 16/20. If you're not waiting until the gas light comes on... you're probably getting about what the truck's estimates are brother.
    Do you always get the same stations gas? A couple stations around my area have gotten busted for watering down their gas...
    My advice, use a different station, and do a few runs from full until right when the light comes on. Take your total miles and divide by 17. See what you're getting. The guys on here that are getting more 2 and 3 MPGs over EPA are either A.) hypermiling a bit B.) Doing mostly highway driving OR C.) BSing.
  18. Mar 31, 2011 at 6:16 PM
    #38
    LostRebel
    Almost Canada, USA
    Huh? This only works if he has actually used 17 gallons. Why not fill the tank up and divide miles by the gallons it takes to fill up. Why estimate how many gallons you used when you can look at the meter on the gas pump and use the actual number of gallons used?
  19. Mar 31, 2011 at 6:24 PM
    #39
    showmeballer
    st. louis
    08 trd off-road
    None yet
    This
    Also, to the guy above in OH, winter gas is a totally different blend that uses more butane and is one of the reasons why winter gas will get you less mpgs compared to summer gas. It isn't the air temp, it is the actual gas.
  20. Mar 31, 2011 at 6:28 PM
    #40
    wheresmikeys
    wheresmikeys Get Some
    Michael
    Red Lodge, Montana
    08 Tacoma SR5 V6 TRD Off Road
    ARB Bumper. Old Man Emu Suspension Dont leave home without it
    I have an 08 V6 Access Cab 4WD with only 15K on it. I have NEVER seen above 17mpg. All stock except ARB front bumper. 255/60/16 winter tires this whole last winter. At 75 on the Interstate i get 16 max and variable driving (interstate, mountain highway, in town, occasional 4WD) I get 14.
    I am anal. I calculate EVERY tanks fuel mileage
    My 98 V6 got 20 on mountain highway and 18 on Interstate
