Need help! Need advice on lift kit and tires!
Discussion in 'Suspension' started by Dr. Muggles, Oct 23, 2011.
  1. Oct 23, 2011 at 1:23 PM
    Dr. Muggles
    Dr. Muggles [OP] New Member
    I need some advice. My tires that came with the truck have come to an end, now it is time for a lift with new rims and tires. Can anyone help me in this process?
    I am looking to put 33" x 10-12" tires with a 3" lift. Is this possible. I have been looking through all of the posts and have been confused, so I thought I would start a thread to get direct help!
    What lift kit should I be looking at?
    Do I need spacers?
    What should I be looking at for rims and tires?
    Thanks,
    2010 Tacoma Double Cab TRD Sport Package 4x4!
  2. Oct 23, 2011 at 1:25 PM
    raswank
    raswank Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    Might help if you tell people the year of truck? 4X4 Pre Runner. Also use the search button bro
  3. Oct 23, 2011 at 4:21 PM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    Why not get the shock that are designed to go with the 885 coils?
    Get the whole OME lift? http://www.toyteclifts.com/index.ph...tegory_id=113&option=com_virtuemart&Itemid=72
    Skip the diff drop. It does not help & can cause damage. I got the 885s & Dakars. Rides great on & off road.
    Dont forget the ToyTec TW discount. http://www.tacomaworld.com/forum/toy...ount-code.html
    Old Man Emu suspension systems are designed, tested, and built in Australia. Four wheelers everywhere should expect a system that will provide the load carrying requirements for work, increased wheel travel for use off-highway, and ride suppleness to eliminate the harshness of washboard roads and choppy city streets. Old Man Emu designs its suspensions for the safest allowable lift, ensuring improved control and handling and increasing wheel travel for excellent off-highway performance. Old Man Emu suspensions also allow you to carry the heavy loads common to expedition vehicles without sagging the springs.
    More About Old Man Emu Suspension Products
    Suspension, especially when referring to 4WDs, is extremely complex. Determining the right solution for each 4x4 requires special attention to many factors, with weight being the most critical. This relationship between vehicle weight and suspension is where Old Man Emu gets its name - the emu is a large Australian flightless bird, when it runs, its powerful legs absorb most of the impact, allowing it to move over all types of terrain while its body remains virtually motionless. This is what Old Man Emu strives to achieve with its range of fully integrated 4x4 shocks and suspension systems. Old Man Emu suspension systems include carefully matched spring and shock combinations engineered to improve vehicle ride, handling and control under various loads.
  4. Oct 23, 2011 at 5:08 PM
    tacomalex
    tacomalex Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    OME all the way. Also get some LR UCA's so your steering doesn't suck.
  5. Oct 29, 2011 at 2:58 PM
    Strautins
    Strautins Well-Known Member
    Nick
    SL,UT
    TRD OffRoad TX Pro
    OME lift, Light Racing UCA, Demello Front, Demello sliders, Brute force rear, TX pro wheels, 285/75s, snorkel, M8000, ARB OBA, Century shell, Relentless skids, Cobra 75wxst
    I have a 2.5" spacer right now, thinking about getting the OME and some LR UCA's. When is it necessary to get a top spacer? I have 285/75/16's on the truck right now and have no problems with rubbing and want at least the same amount of lift so I keep the truck rub free but the ride sucks on the spacers that came with the TXpro package...
  6. Oct 30, 2011 at 9:03 AM
    Strautins
    Nick
    SL,UT
    TRD OffRoad TX Pro
    ***not to hi-jack, just thought that some of the responders on here could quickly answer my question since it was related to the OME lift.***
  7. Oct 30, 2011 at 9:31 AM
    4Wheelin4Banger
    Randy
    You will get around a 2 1/2" to 2 3/4" lift up front on a DC with 885s and no spacers. 1/4" spacer will give you 1/2" lift.
    You got spacers on a T/X Pro or do you mean adding spacers to the T/X Pro shocks & springs?
  8. Oct 30, 2011 at 10:15 AM
    Strautins
    Nick
    SL,UT
    TRD OffRoad TX Pro
    Spacers came installed on my txpro along with an aal. I hate the ride and constantly read great things about OME, I would like to go OME without spacers and just wanted some input. Not sure if it changes anything but I'm ordering an allpro (or similar) plate bumper and winch at the same time I order a lift so I may need 886 coils? Your input is much appreciated.
    Also...I have the txpro wheels so the backspacing was ideal, got away with a 285/75/16 with no body mount chop and no rubbing.
  9. Oct 30, 2011 at 10:27 AM
    4Wheelin4Banger
    Randy
    The guy I got my lift from had a TRD AC with Relentless Fab bumper, winch, sliders and skids. He tried the 886s but "felt like he was being asaulted" so he went back to 885s with a 1/4" spacer. Not sure how much lift he had with that setup (you can PM Sierrahsky and ask) but I got a full 3" without the spacer on my AC.
  10. Oct 30, 2011 at 10:51 AM
    Strautins
    Nick
    SL,UT
    TRD OffRoad TX Pro
    Ok, sounds like I'll try the 885s with a 1/4 inch spacer, LR UCA, and a new leaf pack in the back. Thanks for the input bro. I'll definitely shoot that other guy a PM too.
  11. Jan 3, 2012 at 2:21 PM
    JavaJoe1
    JavaJoe1 Well-Known Member
    Joe
    Florida
    2012 Access cab Pre-Runner SR5
    Secondary air filter removal, AFE Pro Dry, 5100's all around front set at 2.5, 2" AAL in rear, ImMrYo Mirror Bracket, 265/70-17 Grabber AT2's, XD Addicts, wanting to do: BHLM, Satoshi/T-rex grill
