Need help!! No running tail lights...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zac of all trades, May 3, 2016.
  1. Jun 19, 2020 at 9:50 AM
    #61
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Good you found it, thanks for the update.
    Damn I hate LED Lights.
  2. Dec 11, 2020 at 3:20 AM
    #62
    smokier
    smokier Member
    Jim
    2014 Limted Tacoma Blue
    Coming soon - as I learn
    Had the same described problem as the OP from 2016. LOVE this site! Blown fuse behind the 'coin tray' drivers left knee.
    What caused it? Trying to switch out the front DRL/Turn signal with a SWITCH BACK LED. That didn't go so well... :(
    Good news, the tail lights all work again!
    Thanks to the members of this forum, ZERO $ spent fixing my screwup...
    Taco On!
    Smokier
    Jimmyh likes this.
  3. Jul 25, 2021 at 12:13 PM
    #63
    Boulder Taco
    Boulder Taco Well-Known Member
    Pete
    Tampa, FL
    2012 Tacoma TRD OR
    3" ToyTec Lift D.C. 285/75/16's ProComp ES9000 Shocks Avid Light Bar / Sliders Hella Black Magic Fog Lights Black Badges + Black Grille ARE Topper Sockmonkey TRD Decal Bulletproof Fab. TRD Skid Plate Blacked Out Rear Bumper
    Also, same exact problem I was wiring my new Raptor LED's, and must have blown the 10A fuse behind the coin tray. Easy fix.
    Found out the interior fuses behind the coin tray are "Low Profile Mini's", I assumed they were all standard mini fuses.
    But a pack cost $5. Love this site. Has saved me thousands over the years!!
  4. Nov 1, 2021 at 11:59 AM
    #64
    powerw1980
    powerw1980 Member
    2005 Tacoma Prerunner
  5. Nov 1, 2021 at 11:59 AM
    #65
    powerw1980
    powerw1980 Member
    Did you ever figure this out?
  6. Nov 13, 2021 at 5:58 PM
    #66
    nptesta16
    nptesta16 Active Member
    Nick
    Berkeley, CA
    El Guaco Taco: Silver 2001 Tacoma Prerunner V6 TRD off-road
    Does the grease used in 4 pin trailer light connectors conduct electricity (I mean, probably lmao). If so, could the grease be making contact between harness pins and shorting the circuit?
  7. Nov 14, 2021 at 10:26 AM
    #67
    Jimmyh
    SC
    2012 Prerunner SR5
    No, Dieelectric grease is not conductive.
    TnShooter likes this.
  8. May 18, 2022 at 6:33 AM
    #68
    PreRunnerAlabama
    PreRunnerAlabama Well-Known Member
    2015 Black Toyota Tacoma PreRunner I4
    TRD Sport 17" rims Fog Lights OEM Curt Receiver and Hitch
    I just had this problem. Daytime running lights were out front and back, tag light out. Blinkers, reverse light, and brake lights all worked. Looked at my tail fuse it was blown. Replaced now all good. I’m guessing a trailer I recently hooked it up to had a short and caused it to blow.
  9. Oct 26, 2023 at 4:07 PM
    #69
    Gen2GenX
    Gen2GenX New Member
    2012 Tacoma Crew 2X
    2012 PreRunner 2WD Double Cab here... Had the same issue and solved with the same 10A fuse behind the coin tray marked "Tail".
    THANK YOU!
  10. Nov 16, 2023 at 9:46 AM
    #70
    Opc22
    Opc22 New Member
    2015 Toyota Tacoma PreRunner
    Did you ever find the problem? I’ve only switched my cabin driver side fuse box mini profile 10a fuse, which was blown, for a regular 10a fuse and lights still not working. What should my next step be? Is the mini fuse different than the regular? A video on YouTube said they’re interchangeable. I’ve looked under the hood and by the trailer light connection and wiggled things around.
  11. Nov 16, 2023 at 9:48 AM
    #71
    Opc22
    Opc22 New Member
    Did you replace with the same mini profile fuse type? Or regular size fuse?
  12. Nov 16, 2023 at 9:54 AM
    #72
    Opc22
    Opc22 New Member
    Just checked again and new fuse was blown again. Tried another again and it blew immediately after turning on car.
  13. Nov 16, 2023 at 10:24 AM
    #73
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    them you have a short (12V to ground with no resistance) someplace
  14. Nov 16, 2023 at 12:37 PM
    #74
    agmason
    agmason Well-Known Member
    Austin, Texas
    2007 Prerunner 4dr LWB
    I had this happen and it ended up being cheap aftermarket trailer brakes had shorted causing issues with rear brake light fuse. After I disconnected trailer brakes and replaced fuse no more issues. Not sure you are having the same issue, but something to check/consider.
  15. Nov 16, 2023 at 6:21 PM
    #75
    Opc22
    Opc22 New Member
    Tried it and still nothing. Took tail lights apart and diode got power when pressing brakes but not when no brakes [regular running lights]…
  16. Nov 16, 2023 at 6:43 PM
    #76
    Jimmyh
    SC
    2012 Prerunner SR5
    Unplug the tail light assemblies and see if the fuse still blows with them disconnected.
    If it still blows then you have an issue with the truck wiring.
    If it doesn't blow the problem is with one or both of the tail light assemblies.
  17. Nov 16, 2023 at 6:50 PM
    #77
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Dm93 likes this.
