Need help now! In the middle of an install...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DrRabbitFurHead, Apr 11, 2010.
  1. Apr 11, 2010 at 6:49 AM
    DrRabbitFurHead
    DrRabbitFurHead [OP] Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    Can anyone please show me a pic of the Fox rear resi shocks for the REAR. I have ZERO installation instructions and I have 2 bushings, 2 conical washers and a nut.
    Obviously the nut goes on top and I don't want to have to guess on the orientation and order of the other parts.
    Also, there is a loose sleeve and the bolt and nut for the stock configuration is way loose in the bottom of the shock thru hole. Do I need to press out the bushing in the OEM shock and install that in the Fox shock?
    TIA.
  2. Apr 11, 2010 at 6:53 AM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    It should be the same as your stock shocks. It goes (from top to bottom), nut, washer, bushing, frame, bushing, washer.
  3. Apr 11, 2010 at 6:54 AM
    Brunes
    Brunes abides.
    Rotorhead
    Concur with Viet.
  4. Apr 11, 2010 at 6:59 AM
    DrRabbitFurHead
    Salem, VA
    Awesome, what about the bolt and nut that go through the bottom of the shock. The FOX rear shocks have a large hole that looks like I need to press out the bushing in the stock shock and install it in the FOX shock???
    Is that the case?
  5. Apr 11, 2010 at 7:08 AM
    DrRabbitFurHead
    Salem, VA
    Here's a pic of what I'm trying to describe. See how the FOX shock has a larger opening than the sleeve supplied with the kit and the bolt...
    Also, is that Viet Tran? Tim's little brother?
