NEED HELP NOW!!!
Discussion in 'Performance and Tuning' started by 05RedTaco, Nov 18, 2012.
  1. Nov 18, 2012 at 9:43 AM
    05RedTaco
    05RedTaco [OP] Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I am installing JBA long tube headers they have four o2 sensor bungs. On each header there are two bungs. Each header has a bung on one pipe coming from one cylinder so the o2 sensor will sample exhaust gas from only one cylinder than another bung at the collector so the o2 sensor will sample exhaust gas from all three cylinders.
    Where is the best spot to put the oxygen sensors?
  2. Nov 18, 2012 at 3:28 PM
    s7racing
    s7racing Well-Known Member
    O2 sensors go in the upper hole, closet to motor.
  3. Nov 19, 2012 at 7:32 AM
    05RedTaco
    Tony
    Scottsdale
    Thats where I put them...
  4. Dec 22, 2012 at 4:45 PM
    Christianson.USMC
    Christianson.USMC WOUNED WARRIOR MARINE
    Will
    Jacksonville, NC
    2011 4wd Sport 4.0 sbed JBL Dcab,3'' lift etc
    TRD Intake, Borla exhaust,JBA long tube headers, DT Y Pipe, Light Racing UCA's, Jet Throttle Body spacer, lifted 3.5" front 3"back. Grill guard w/ KC lights, Stepsides, Tint, hood protector, window visors, Caltrend neopreme seat covers, weathertech mats, HID fog and headlights, 1" wheel spacers front .5 rear, brakelight guards,265/70/r17 till they die and can get 33's, more to come
    did you just plug the second one and put the URD sim on the one at the start of the Y pipe?
  5. Dec 23, 2012 at 12:38 AM
    lemon177
    lemon177 Well-Known Member
    Matthew
    Oahu
    09 tacoma 4x4 sport pyrite mica
    TRD supercharger, URD 2.85" stealth pulley, TRD exhaust, TRD intake, DTLT headers, URD y-pipe, TRD boost gauge, PLX DM100 touch with OBDII and SM-AFR modules, 885 OME 3", Icon UCAs, Satoshi grill, Solid rear window, SCS stealth 6, 285/75/17 toyo AT2.
    Unless you're tuning with a standalone, you should go with the stock location. Otherwise, you may need to extend the harness to reach the lower bung.
  6. Dec 23, 2012 at 5:17 AM
    Christianson.USMC
    Will
    Jacksonville, NC
    The stock location for the second sensor is the top of the Y pipe, with the URD SIM i can reach either locations. So plug the second bung on the header and use the stock location on the Y pipe.
  7. Dec 24, 2012 at 6:07 AM
    slo13zx3
    slo13zx3 Well-Known Member
    Brian
    forest city pa
    14 trd off 6speed nav
    Go with the one that takes all 3
