need help on 5100 shocks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 96fido96, Oct 25, 2011.
  1. Oct 25, 2011 at 7:50 PM
    96fido96
    96fido96 [OP] Well-Known Member
    ESQ
    ONTARIO CA
    6cyl 4x4 first gen
    hey guys this may be a funny question but i went to the web site for Downsouth motorsports. What is the difference for the "pre load adjustable and the performance shocks" My other question is should i get new springs my truck has 124k miles, how dificult is it to change front and rear shocks
  2. Oct 25, 2011 at 7:54 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    preload adjustable shocks basically give you lift. but its only the front that has that. Im not possitive about on a 2nd gen but it cant be much different than a 1st gen. its really easy to install
  3. Oct 25, 2011 at 8:04 PM
    96fido96
    ESQ
    ONTARIO CA
    6cyl 4x4 first gen
    would i need new springs
  4. Oct 25, 2011 at 8:22 PM
    j1999t
    j1999t Well-Known Member
    Justin
    Northern Colorado
    traded it in
    only if the ones on your truck are worn out
  5. Oct 25, 2011 at 8:23 PM
    96fido96
    ESQ
    ONTARIO CA
    6cyl 4x4 first gen
    ok thanks you guys:D
  6. Oct 25, 2011 at 8:24 PM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    The "Big Nig"
    Lifted, Locked, Armored. Ready To Wheel.
    if your truck has 124k miles i'd say you need new springs
  7. Oct 25, 2011 at 8:25 PM
    96fido96
    ESQ
    ONTARIO CA
    6cyl 4x4 first gen
    woops soory where can u buy new springs just incacse i need them:rolleyes:
  8. Oct 26, 2011 at 12:05 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    Same place. You can also check out ToyTec. Don't forget your TW discount.
  9. Oct 26, 2011 at 10:04 AM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    Why exactly would he need new springs?
    Front?
    Rear?
    Details.....
  10. Oct 26, 2011 at 10:10 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Just plan worn out. They lose responsiveness. I'm willing to bet his rears are close to flat.
  11. Oct 26, 2011 at 10:10 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    After 124k miles of soaking up bumps in the road, they're probably sagging and showing their age. The rear leaf springs would show it much more so than the fronts since the 2nd Gen leaf pack is pretty weak. If you bottom out with little to no load, you need a new leaf pack. The coils seem to hold up a bit better.
    Installing the fronts requires the use of a spring compressor. You can buy a cheap one, rent one from a local auto parts store or bring the new shock and coil to a shop and have them assemble them for you (well worth the $$ in my opinion to have them do it). The rears are very simple, unbolt old shocks, bolt in new ones, done. Don't even need a lift for the rears. I had to cut my old shocks off because the top nut was rusted on so badly I couldn't budge it. You might get lucky, dose it with PB Blaster the night before and it might come lose for you.
  12. Oct 26, 2011 at 10:11 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Tooooo slow. :D ..............but much more informative. :pout:
  13. Oct 26, 2011 at 10:11 AM
    4Wheelin4Banger
    Randy
    With 124K miles there is a good chance are they are sagging and worn out. Do your rear leafs smile, frown or keep a streight face?
  14. Oct 26, 2011 at 10:13 AM
    Pugga
    Massachusetts
    F-150 Mod
    Yeah, you got me beat on that one... I'm losing it in my old age :eek:
  15. Oct 26, 2011 at 12:27 PM
    thinkingman
    redmond WA
    I agree on the rears...I installed airsprings to counter the sag.
    I like having adjustability.
    I was really referring to the fronts.
