need help on disturbing sound
Discussion in '1st Gen. Tacomas (1995-2004)' started by crazyjeys, Jan 22, 2011.
  1. Jan 22, 2011 at 11:15 PM
    crazyjeys
    crazyjeys [OP] Well-Known Member
    tw gurus, i need your help. i just noticed a distubring sound last night from my taco. it's a 4x2 double cab 4cyl (32in tires, 5100's at 2.75). at first, when i hit a bump on the left front wheel, i hear a rattling sound. almost the same sound as a bad ball joint. then when i got home, i took it for another spin, and now it seems that the sound is affected by the right front wheel as well. i jacked up the truck and checked for wheel play but there was none. now it seems that the rattling sound is coming from the front center of the truck. take note that there's no steering feedback whenever i hit a bump and hear a sound. and the sound does not come out on speed bumps. just on small crevices on the road. hope someone can shed a light on this or someone had the same experience.
  2. Jan 22, 2011 at 11:43 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    sway bar?
  3. Jan 23, 2011 at 3:04 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Need a little better definition of your "rattling" sound, i.e; Clunk sound like a bad swaybar bushing, etc. :cool:
  4. Jan 23, 2011 at 6:39 AM
    crazyjeys
    I'll go try to torque evyrything down. The rattling sound is somewhat like a "tigidig tigidig" kind of sound whenever I hit a crevice on the road. Is it common to have a bad sway bar bushing or a steering rack bushing. I don't go off road. Just a daily driver.
  5. Jan 23, 2011 at 2:05 PM
    troopa4life
    troopa4life Member
    Virginia
    02 2.7 Reg Cab 5 Speed
    Doug Thorley Shorty Headers
    The sound you are describing might be your shocks... Make sure they are tight
  6. Jan 23, 2011 at 2:49 PM
    drade
    drade BRUINS 4 LIFE
    ME
    2016 Toyota Tacoma TRD Off Road Short Cab Silver
    TRD PRO skid plate, wet kole seat covers, tint all around, red line tuning quick Lift system, paint protection film, gloss blacked out OEM emblems, electric start, heated seats.
    Have this same issue; but its in the front left tire wheel well. Go over little bumps and un even pavement and get this soft rattling sound. Sometimes a little, sometimes a lot. Going to the dealership thursday:mad::mad::mad::mad:
  7. Jan 24, 2011 at 8:05 AM
    crazyjeys
    it's not the shocks. they are new and the bolts are tight. i tried to tighten everything every bolt and found one issue. when i was tightening one of the stabilizer links, one bolt just goes on and on. it's not loose but it does not tighten. i tried the one on the other side and it is tight. could it be the one? how do you know if a stabilizer link is bad?
  8. Jan 24, 2011 at 8:44 AM
    Mod
    Mod Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    On a sway bar end link for a 1st gen, there is a slotted area on the end link shaft where you can hold it with a wrench and tighten down the link nut/bolt.
    Lower ball joint bolts tight??,,no slop in ball joints??
    Do you have metal push-in centercaps on your wheels?? if so those could be rattleing.
  9. Jan 24, 2011 at 8:53 AM
    crazyjeys
    i'll try to tighten up the bolts again on the sway bar end link.
    lower ball joints are okay. and i don't have push in centercaps too.
