Need help on front end
Discussion in '1st Gen. Tacomas (1995-2004)' started by Williams09, Jun 26, 2022.
  1. Jun 26, 2022 at 2:20 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I venture your Tie Rod adjustment is so far off it is compounding problems.
    This is so very hard when you don`t really know what your looking at to figure out.
    A year ago you might not remember if your steering wheel and the rack where centered when you connected them this could also be causing problems.
    little things that added up make a major problem.
    If I was close I would be glad to help.
    check your regional forums someone local might be able to help in person.
  2. Jun 26, 2022 at 2:20 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    I hear you. Locknuts on the tie rod would not last with my OCD.
    McGeorge Toyota is one of the best with part pricing.
    https://toyotaonlineparts.mcgeorgetoyota.com/
    Just using a 95, 6cyl, AT 4WD - this is what I come up with when searching:
    LEFT SIDE (4504739175) - $ 49.00
    https://toyotaonlineparts.mcgeorget...ing-Tie-Rod-End-Left/63130356/4504739175.html
    RIGHT SIDE (4504639295) - $ 49.00
    https://toyotaonlineparts.mcgeorget...ng-Tie-Rod-End-Right/63544768/4504639295.html
    Now of course I would call and confirm by giving them a VIN number to be sure that is the correct part before ordering.
    Its easy to muck up the thread count when installing outer ties which then of course messes up your alignment. Not saying that is what happened in your situation but it happens.
    A couple of reference videos -
    https://youtu.be/AVQHgcXEhpE
    https://youtu.be/--HcOQlv03U
    https://youtu.be/-9koqIn0ONE
    https://youtu.be/RwvOgxx5SmQ
  3. Jun 26, 2022 at 2:23 PM
    Tbrad7128
    Tbrad7128 Well-Known Member
    Tyler
    Boerne Texas
    2003 Tacoma 3.4 v6 TRD double cab 4x4 elock
    Do you know of anyone that has another tacoma of similar year that you can compare and measure thread distances? thats probably where i would start..
    When you pull the cluster make sure you disconnect the battery. That flimsy circuitry back there shorted out on mine and I had to replace the whole thing.
    If you spend a little time there are a few toyota dealerships around that sell largely discounted OEM parts for these trucks online (Mcgeorge toyota comes to mind). If i can find OEM for close to knockoff price i pay a little more for OEM.
    Williams09[OP] likes this.
  4. Jun 26, 2022 at 2:24 PM
    Tbrad7128
    Tyler
    Boerne Texas
    Williams09[OP] and Area51Runner like this.
  5. Jun 26, 2022 at 2:26 PM
    Area51Runner
  6. Jun 26, 2022 at 2:32 PM
    Williams09
    Williams09 [OP] Member
    Sam
    Arizona
    1995 toyota tacoma base 3.4 4x4
    Ok since the tie rod ends have been switched multiple times I'm not sure which is the corrective anymore. This is on the passenger side. It is labeled RH the L is on the driver side. Are we once again backwards? Front of the truck is to the right of the tie rod end.
  7. Jun 26, 2022 at 2:33 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    You are orientated the correct way now. L is driver. R is passenger.
  8. Jun 26, 2022 at 2:35 PM
    Williams09
    Sam
    Arizona
    Thank you. That's how they were when it was catching and stopping the wheen from rolling when turned.
  9. Jun 26, 2022 at 2:55 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You need to be careful on the number of turns lock to lock. You have too many going one direction and not enough going the other direction. They should be equal.
    You are in danger of breaking your ribbon cable in the steering column. You will end up with an air bag light or non functioning cruise or horn if you don't correct this.
  10. Jun 26, 2022 at 2:57 PM
    Williams09
    Sam
    Arizona
    Like how many turns they go on?
  11. Jun 26, 2022 at 3:00 PM
    koditten
    Kirk
    Central Michigan
    Going by memory here.
    I think it's 2.5 revolutions each way.
    You will need to disconnect the steering u joint, center the wheel, then reattach the steering joint.
    Of course make sure wheels are straight before you do this.
  12. Jun 26, 2022 at 3:00 PM
    Area51Runner
    Honestly, the alignment tech should have corrected this issue. I remember when I first did my inner and outer tie rods. I seriously botched it and screwed up the steering wheel position. More threads showing on one side vs another, etc. First shop I went to (Toyota - go figure), kicked it back and suggested I replace the UCAs. Second shop (alignment only shop), resolved the issue and put me very close to within spec. Still ended up replacing UCAs because of an OME suspension lift but that is another chapter...
    @koditten is spot on with the steering wheel. You have to be very careful or you'll end up with another repair.
  13. Jun 26, 2022 at 3:03 PM
    Area51Runner
    Check out tim's vid he talks about thread and turns... click below and it'll play from that time stamp. Its a wash now since you didn't in the beginning BUT it still gives you a good idea of what you're dealing with.
    https://youtu.be/--HcOQlv03U?t=240
  14. Jun 26, 2022 at 3:04 PM
    Williams09
    Sam
    Arizona
    Thank you all so much!
    Area51Runner likes this.
  15. Jun 27, 2022 at 7:02 PM
    #35
    AmherstAndy
    AmherstAndy Well-Known Member
    Andy
    Masshole
    2003 2.7L 5 speed, 4x4 J shift, Xtracab
    I can’t picture how this would even be possible, no matter how badly adjusted the outer TREs are. Can you post some more pictures that clearly illustrate this interference?
  16. Jun 28, 2022 at 6:30 PM
    #36
    Williams09
    Sam
    Arizona
    The CV axels will be here Friday and then the alignment will be done. As of right now this is how it looks when turned to the driver side.
  17. Jun 28, 2022 at 8:17 PM
    #37
    AmherstAndy
    Andy
    Masshole
    What size tires? Are those factory wheels? If not, what are the specs (diameter, width, backspace)?
  18. Jun 28, 2022 at 8:27 PM
    #38
    AmherstAndy
    Andy
    Masshole
    Your picture in post 26 shows the tie rod attaches to the lbj within the radius of the rotor/backing plate (as it should), so I don’t see how it’s possible for the wheel to fit over the rotor/backing plate, *and* have the tie rod make contact with the tire, unless the steering stop is missing from the passenger side? Idk, this baffles me.
  19. Jun 28, 2022 at 9:21 PM
    #39
    Williams09
    Sam
    Arizona
    265/70/16 is the size. Unsure what the backspace is.
  20. Jun 28, 2022 at 9:22 PM
    #40
    Williams09
    Sam
    Arizona
    It all baffles me.
