Need help on leveling my truck
Discussion in 'Suspension' started by jwj202, Nov 6, 2012.
  1. Nov 6, 2012 at 5:15 PM
    jwj202
    jwj202 [OP] Well-Known Member
    Joey
    Mississippi
    '10 silver TRD Offroad SR5
    I am trying to level my 2010 DCSB but dont know to much about leveling kits. i want BFGoodrich KM2 tires 285/75/16. Yes i know im going to have to cut a lot but what is the best and cheapest way to get 2.5 inches of lift in the front to level the truck.
    Post links also if you have any.
  2. Nov 6, 2012 at 5:22 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Bilstein 5100s set at 1.75 will level the truck nicely. You can run 285s with that amount of lift but you'll have to trim
  3. Nov 6, 2012 at 6:02 PM
    jwj202
    Joey
    Mississippi
    will i have to do anything to the back or could i leave it stock without it riding like a wood wagon?
  4. Nov 6, 2012 at 6:04 PM
    BulletToothTony
    BulletToothTony Space for rent
    You can call me Susan if it makes you happy.
    if you set the billies at 1.75 you wont have to add anything to the rear. if you set them at 2.5 (most do to run 285's) you will need an AAL to be level...
  5. Nov 6, 2012 at 8:37 PM
    jwj202
    Joey
    Mississippi
    So front set at 2.5 with stock coils and stock rear shock with rear AAL will level the truck with no rake?
  6. Nov 6, 2012 at 8:52 PM
    dlooney
    dlooney Well-Known Member
    Dennis
    Wilmington NC
    07 TRD Sport PreRunner
    Satoshi w/ hella 500s mounted behind, 20% tint, 6K HID retro headlights, 4300k HID fog lights, DTRLs, plastidipped front valence, cb mount
    It'll ride rough with billies maxed out at 2.5...
  7. Nov 6, 2012 at 8:55 PM
    jwj202
    Joey
    Mississippi
    truck only has 39k miles on it. Would a 2.5 inch strut spacer ride better?
  8. Nov 6, 2012 at 10:11 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Nope.....will be worse! I wouldn't go above 1.75" or get some coilovers!
  9. Nov 7, 2012 at 4:17 PM
    jwj202
    Joey
    Mississippi
    1.75" wont level it though or will it
  10. Nov 7, 2012 at 4:40 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Factory rear is 1.5" higher than the front.....search for some pics, I know guys here have done that!
    The .85" setting is a good option too and will allow you to fit a bigger tire once you trim!
  11. Nov 10, 2012 at 2:47 PM
    hierks
    hierks Member
    Michigan
    Silver TRD offroad
    Bone stock so far
    When people say trim, what is actually getting trimmed? Plastic, metal? Anyone have pics of what they had to trim?
  12. Nov 13, 2012 at 4:56 PM
    jwj202
    Joey
    Mississippi
    anyone have pics of front bilstein shock at 2.75" with 33" tires. Please post pics
  13. Nov 14, 2012 at 10:26 AM
    Moving4ward
    Moving4ward Active Member
    New Jersey
    2011 2.7L 5-speed Taco 4x4
    Toolbox. Looking for wheels&tires!!
    Bump!
  14. Nov 14, 2012 at 7:14 PM
    jwj202
    Joey
    Mississippi
    anyone with front billys at 2.75 inches and stock coils with 33" tires?
  15. Nov 14, 2012 at 8:43 PM
    Moving4ward
    New Jersey
    I thought they only went up to 2.5?
  16. Nov 15, 2012 at 6:02 PM
    jwj202
    Joey
    Mississippi
    just put the truck in the shop. 285/75/16 km2's with billys at 1.75" and stock rear. will have pics tomarrow
  17. Nov 15, 2012 at 6:12 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    IMO get an above coil spacer rather than compressing your stock coils. it will ride nicer, and is cheaper.
    I have a 3'' front spacer, and a 1'' rear block, sits level
