Need help on lift plz
Discussion in 'Suspension' started by joshtaco08, Apr 12, 2017.
  1. Apr 12, 2017 at 7:56 PM
    joshtaco08
    joshtaco08 [OP] Active Member
    Josh
    I just installed 5100and 2886 coils and now the 2 lower control arm pivot bolts won't line up with the spindle .. just wondering y the spindle won't go down enough to line up the holes.. tie rode?
  2. Apr 12, 2017 at 9:49 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    you may need to put a jack under the lower BJ to bring it up some to meet the spindle
  3. Apr 12, 2017 at 9:53 PM
    Silverspool
    Silverspool Come at me Bro!
    Frank
    DFW
    18T4RORP 17GT350
    Anyone seen my wallet?
    If you went that route and its too close, youre gonna have to loosen the cam bolts to get more movement from the lca. If its too far, do as above mentioned, use a jack on the lca.
    Assuming youre getting an alignment soon anyways, cam bolt movement wont matter as itll be sorted out. If you arent getting an alignment right away, mark the cam bolt positions in case they rotate when loosening/tightening.
  4. Apr 13, 2017 at 6:38 PM
    joshtaco08
    Josh
    Ighty it's all in now.. but the truck leans almost an inch from one side to other ? Is that just because the gas tank is on the side that it's leaning on
  5. Apr 13, 2017 at 6:41 PM
    Silverspool
    Frank
    DFW
    18T4RORP 17GT350
    Shouldnt cause an inch worth. Notches the same, spring perch correct on both sides?
