Need help on rear lift
Discussion in 'Suspension' started by lucabi, Feb 21, 2013.
  1. Feb 21, 2013 at 10:32 AM
    lucabi
    lucabi [OP] Well-Known Member
    lucabi
    Baton Rouge, LA
    10 DC TRD
    Need some advice and suggestion on what I can do to get an addition 1" or 1.5" of lift in the rear after putting a camper on. The problem is that I have the TSB on one side, the other still have the non-TSB 3 leaf (long story:mad:). Don't have the fund to get a new leaf pack. What are my options?
  2. Feb 21, 2013 at 10:37 AM
    acdronin
    acdronin Well-Known Member
    I would probably look into either trying to track down an additional TSB leaf (I wouldn't have a clue as to how hard that would be), or pull the one TSB out, but either way probably your cheapest option would be to install a 2 inch AAL from someone like Wheeler's Off Road (they are a vendor on this site), with the camper shell it will settle back down a bit probably to 1 1/2 inches.
  3. Feb 21, 2013 at 10:45 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    as soon as you have something imbalanced like this, your goal is
    to get the correct parts and balance it out. trying to correct an
    already incorrect setup, by throwing more 'patches' on top, may
    end up with a dangerous vehicle handling scenario, especially with
    an added load like a camper.
    best advice...match up your suspension on both sides with equal
    spring packs first.
    no funds to do so ? gotta find some funds.
    you may be able to strike a deal and nab some springs on the cheap,
    or trade, or something.....
  4. Feb 21, 2013 at 3:39 PM
    lucabi
    lucabi
    Baton Rouge, LA
    10 DC TRD
    The weird thing about this is that the truck is level right now, its not leaning at all. I don't know how its doing that and there are no tags on the spring to know what the part number is.
    The camper I was referring to is just an ARE topper or cap, whatever they called it.
    Do you think it would be OK to just add another flat leaf on the 3 leaf pack and install AAL on both side?
  5. Feb 21, 2013 at 3:44 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Wait how do you have the tsb on one side only? Are you still under warranty? I would go to the dealership and try to get the tsb on both sides, then do AAL. If you want to keep the truck at stock height get some firestone riderite airbags to help handle the added weight
  6. Feb 22, 2013 at 8:09 AM
    lucabi
    lucabi
    Baton Rouge, LA
    10 DC TRD
    I didn't notice it till after the warranty was over with. It was the nearest dealer in town that would agree to do the TSB and I have had previous issue with them . I would not even trust them to vacumn my carpet now.
    I have 5100 up front at 1.75 and its nose high after putting the topper on, just wanted to level it in the rear.
    I'm going to call Toytec and Wheeler for recommendations.
