Need help! Orlando!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Scoobarooo, Sep 7, 2015.
  1. Sep 7, 2015 at 9:07 PM
    Scoobarooo
    Scoobarooo [OP] Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    Does anyone in Orlando know how to do the "Alternate Side markers/turn signals" mod? I've read the write up and I just don't get it. Could someone meet up and help me?
    Or can someone simply explain it better?
  2. Sep 9, 2015 at 9:04 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    easy explanation #1: you have to cut a bigger hole in the back of the housing to add a different socket (1157 usually) to get the dual function. Then have to tap the wires to the run and turn signal wires.
    easy explanation #2: you have to drill a second hole in the back of the housing to put another socket/bulb in to get the dual function. then have to tap the wires for the second socket to the turn signal wires.
