Need help, P0420 and P0300
Discussion in 'Technical Chat' started by Vegas Tacoma, Jul 21, 2017.
  1. Jul 21, 2017 at 11:37 PM
    Vegas Tacoma
    Vegas Tacoma [OP] Well-Known Member
    Brian
    Las Vegas
    06 prerunner sr5(RIP) 2018 Focus Hatchback
    Hi, I have a 2006 Tacoma and had the check engine light come on with codes P0420 and P0300, vehicle has 187634 miles on it, I'm hoping that I don't need a new catalytic converter, any help greatly appreciated
  2. Jul 22, 2017 at 12:01 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    I would start with o2 sensors and checking spark plugs.
    Vegas Tacoma[OP] likes this.
  3. Jul 22, 2017 at 2:05 AM
    Vegas Tacoma
    Brian
    Las Vegas
    Thanks, will be checking that in the morning, up stream or down stream?
  4. Jul 22, 2017 at 3:41 AM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    p0420 is common when the gas cap is not sealed. Do you have an aftermarket gas cap? If so, that can cause that code. If it is OEM gas cap, make sure it is tight and make sure the gasket is not cracked and worn out. As for the 0300 code, I would clear it and see if it comes back. When were the spark plugs changed? If it has been a while or if it has not been done, that would be my first guess. I don't think it would be O2 sensors, as those typically throw a different code. I can't remember what code it is, but there is a code specifically for the O2 sensors if I recall correctly.
  5. Jul 22, 2017 at 8:58 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    As cheap as they are I would just replace all of them. As mentioned about also check gas cap. I wouldn't rule out a head gasket failure as well. Run a leak test and compression test to rule that out
  6. Jul 22, 2017 at 9:47 AM
    Vegas Tacoma
    Brian
    Las Vegas
    @irayfz6, how can a loose or bad gas cap cause a catalytic converter efficiency code
  7. Jul 22, 2017 at 10:20 AM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    I would love to explain, but I don't know the answer. However, I have seen this code on three different vehicles, and in each case it was the gas cap. Two of them had aftermarket locking caps, one had a very old OEM cap with a dried out, cracked gasket. When I couldn't diagnose my issue the first time I encountered the code, I turned to forums and read somewhere on a thread that it is common for a loose gas cap to throw that code.
  8. Jul 22, 2017 at 10:25 AM
    Bishop84
    Bishop84 Well-Known Member
    Gas cap codes are p0455 (gross evap leak) not p0420 (cat effic below threshold).
    Don't change 02 sensors either, they are working and are telling the ecu that the catalytic converter has failed on bank 1. Very rare that bad o2 sensors can trigger p0420 because they need to work to show the rear sensor swinging with the upstream.
    For me, I would go after the misfire first. A serious misfire can cause raw fuel to hit the catalyst and wreck it. Check plugs and wire condition first, inspect cylinders and see if any are washed with fuel.
  9. Jul 22, 2017 at 10:29 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I got a P0420 when I was out wheeling one day after filling up at a 76 station like I always do (different station though a long ways from home). Cleared the code on the trail and it popped back up right away. Gas cap was tight (first thing I checked). Went home, cleared it and filled up again and its stayed off for a few months now, even on other wheeling trips. Checked my OBDII scanner and no codes. Chalked it up to some funky gas but I probably just got lucky there.
  10. Jul 22, 2017 at 11:00 AM
    Vegas Tacoma
    Brian
    Las Vegas
    Thanks all for your help, I'm beginning to lean towards a bad tank of gas, on other vehicles that I've seen through a P0420 they had drivability issues with the code, I don't have any drivability issues at all, I'm also beginning to wonder if the random misfire was from bad gas
  11. Jul 22, 2017 at 11:04 AM
    eon_blue
    Azusa, CA
    Same here. Mine drove fine other than the code that kept popping up while I had that tank of gas. Hasn't come back since, hopefully your's is the same. I'd run some Lucas Fuel system treatment through the tank a few times as well for good measure (or Seafoam or whatever floats your boat).
  12. Jul 22, 2017 at 11:04 AM
    Old Marine Cal
    Old Marine Cal Well-Known Member
    2015 MGM DBLCAB
    Brian, these are super serious codes and can only be cured by upgrading to a 3rd gen stack.
    So sorry...
    Unchained 5150 likes this.
  13. Jul 22, 2017 at 11:39 AM
    Vegas Tacoma
    Brian
    Las Vegas
    Hell no, I think I may have just figured them out, hooked up my friends factory Toyota scan tool, and found some other codes, he told me to start with an oil change, I know I'm about a 1000 miles over due at the most, but money's been tight, found codes for timeing, and the VVT works off of oil pressure, so he thinks there's not enough oil pressure
  14. Jul 22, 2017 at 8:46 PM
    Vegas Tacoma
    Brian
    Las Vegas
    Well, I cleared the codes, changed the oil, and added a bottle of Heet to the fuel tank, been driving around all day and so far no check engine light
    Old Marine Cal and irayfz6 like this.
  15. Jul 23, 2017 at 6:31 AM
    Old Marine Cal
    2015 MGM DBLCAB
    Nice
    I would have never guessed oil.
  16. Jul 23, 2017 at 12:50 PM
    Vegas Tacoma
    Brian
    Las Vegas
    Neither would I, but hooked up my buddy's factory Toyota scan tool, and found other stuff, and looked at some live data, the VVT system works off of oil pressure so, I last did an oil change in February, so by now the oil was starting to degrade and couldn't supply enough pressure to the VVT system, so it was throwing the ECU off
