Need help picking out my X-mas gift lift kit
Discussion in 'Suspension' started by Jord4n007, Nov 26, 2022.
  1. Nov 26, 2022 at 5:58 PM
    Jord4n007
    Jord4n007 [OP] Active Member
    Jordan
    New Orleans
    2022 TRD Sport Double Cab Magnetic Gray Metallic
    RetraxProXR Roll-up bedcover, Uniden R8 Radar Detector with mirrortap/mount, Husky X-act Contour floormats, MESO Hex Rack, MESO Mini Keypad Dongle, MESO Fuse Block, Carlinkit Android dongle (gives you fully unlocked android OS through factory touchscreen, youtube/netflix/etc and wireless apple carplay)
    Hi all I have a 2022 4 door sport RWD. I do not do much off-roading with it other than to pull my ATV out of the mud or something on the occasion it gets stuck. I am looking for something that will be reliable and look good. I would like to do around a 6” lift with 35” tires. The suspension is currently bone stock. I have been looking at the Rough Country kits on Black Friday sale but was hoping to get some opinions from some more experienced guys. Thanks.
  2. Nov 26, 2022 at 6:11 PM
    Bishop84
    Bishop84 Well-Known Member
    The more you spend the better it will ride.
    The cheapest 6” lift is just giant spacers on factory shocks. It will be big but that’s it.
    I’d recommend any 6” kit that comes with full coil overs.
    Typically a good kit is 3000$. cheap ones are 1200-1500.
    Rough country is more of a bargain brand. Ideally for 6” BDS or Fabtech
  3. Nov 26, 2022 at 6:15 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    RWD? Then you have to go long travel.
  4. Nov 27, 2022 at 8:43 AM
    Jord4n007
    Jordan
    New Orleans
  5. Nov 30, 2022 at 7:45 PM
    Stang066
    Stang066 New Member
    Senoia Ga.
    2013 Tacoma TRD off road
    Weather tech floor liners, spyder HID headlights, HID fog lights, mesh grill, LED interior.
    Hey Jord4n007, I just purchased a 2015 TRD OR to replace my 13 TRD OR that I totalled! The 2013 was stock front and rear. It is the same truck with around 200k less miles and it already had installed the RC 6” lift from the previous owner. It’s on 295/55r20 nitto ridge grappler tires. It has stock Bilstein B6 struts in the front with and RC Nirto shocks in the rear. It rides a little rough, however the rear springs are shot from heavy loads being hauled regularly. I read that rear spring wrap is common when installing lift blocks in the rear. I’m looking to replace them with a lift spring related for heavier loads. It steers well and drives good to for such a big lift.
