NEED HELP PLEASE!!! Change plugs truck wont run right
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BigE taco, Jun 25, 2016.
  1. Jun 25, 2016 at 8:12 AM
    BigE taco
    BigE taco [OP] Well-Known Member
    Eric
    Sarasota, FL
    19 TRDOR DCSB
    19 TRD OR DCSB Cement Falken Wildpeak AT3W 275/70/17 TRD Sema Pro TRD Pro Fox Shocks with Wescott lift Icon AAL progressive leaf pack Freedom Off Road UCA ECGS Bushing SSO slimline hybrid bumper in Zeak 12000lb winch Rigidhorse 20" led combo light bar Taco Garage "TRD Pro" Grill RC TuningFL OTT mild/medium tune Rav4 blindspot mirrors Seat Jackers driver seat Tri fold hard bed cover...came with truck Magnus side steps...came with truck, don't like them Tufskinz Inferno various interior items Auxbeam led low beam headlights "TRD PRO" style fog lights "TRD PRO" style skid plate Meso Custom Total Tail Stg 1 OEMAudio speakers Multi Ch amp, Sub amp and Toyota Gain Knob 09 TRD OR DCSB....sold Falken wildpeak at3w 265/75/16 TRD Pro Kit with Headstrong Prog. AAL TRD Seat Covers TRD Drop filter TRD Exhaust Led headlights and fogs Hidden light bar Led interior lights Pioneer Avic-F900BT Kicker speakers swap Kicker Solo 10" Kicker kx400.1 misc..$$$ spend on unnecessary things AVS in channel visors Trifecta tri fold Toyota Bed Extender Toyota Skid plate
    Hey Guys I need some help please.
    I am doing maintenance this morning and now I have problems..
    I have followed each guide on TW for these items to make sure I did everything right.
    I changed each spark plug one at time used dielectric grease and anti seize, cleaned MAF sensor with CRC MAF cleaner sprayed the wire things lightly and sprayed down inside the tube, unbolted throttle body but left tubing on and just cleaned the dirt and grime with CRC TB cleaner and lastly removed secondary filter.
    I did each plug/coil one at time to minimize any errors. I remove MAF from air box. didn't touch any wires. Lefted everything TB.
    I go to start the engine and it didn't crank over right away but I think thats just the TB cleaner. then noticed the idle higher then normal (above 1000rpm), took it for a spin to see if things just need to burn off and the auto trans gears are not shifting normal.
    Things just don't feel normal...... WTF!!!!
    Anybody have any input
  2. Jun 25, 2016 at 9:34 AM
    BigE taco
    Eric
    Sarasota, FL
    19 TRDOR DCSB
    Disregard.....I forfor to unplug battery. Works fine now.
  3. Jun 25, 2016 at 9:46 AM
    05tacomabro
    05tacomabro will work for truck parts...
    Alex
    Tucson
    05 dcsb trd OR, 06 xrunner, 73 fj 40
    Icon ex. Travel co's, spc uca's, bamf lca skids, 1" body, all pro heavy duty sliders, expo springs, BAMF shackle hangers, 14" bilstein 7100, rear frame box, custom rear frame crossmember, ifs skid, transmission skid, t-case skid(modified by @jeepandrew for exhaust reroute and more beef), custom k&n intake, flowmaster, diff breather mod, stereo with nav/speakers/subs, coverking tactical ballistic seat covers, Baja utility rack, lots of bed liner, anytime fog mod and steel braided brake lines, energy suspension rad support bushings, abs kill switch, cali raised ditch lights, fsr rtt. Lots of plans, little money....
    This was going to be my only suggestion. Glad you found your solution.
  4. Jun 25, 2016 at 9:50 AM
    Frogging
    Frogging Well-Known Member
    DEREK
    ORLANDO, FL
    DCLB 4.0 2wd
    ASV vent visors LED tailgate brake light Weathertech floor mats Wish list:Maxtrac Spindles New leaf pack Extended rear shocks Braided Brake lines Konig countersteer Anodized bronze 285/70/18 tires NST Crank lite pulley setup XTP intake manifold spacer Neoprene seat covers Fiberglass fenders Power sliding rear window 1" Spacers for rear wheels
    Such fear in the first post and sigh of relief(nothing to see here) on the second post.... i know this feeling too well. glad it was simple
  5. Jun 25, 2016 at 10:50 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I would be curious to know why a spark plug change and/or all/some of the other items mentioned caused the idle speed to double?
  6. Jun 25, 2016 at 10:57 AM
    eon_blue
    Azusa, CA
    Not sure but I know from experience that after cleaning the MAF sensor and putting it back in (and disconnecting the battery), the engine will idle weird for the first few to several minutes. Sometimes too low, other times too high but after driving around for a bit it always goes back to normal. Probably an ECU readjusting thing.
  7. Jun 25, 2016 at 11:03 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Yep! From the mas cleaning and not a plug change. Happens to all vehicles if you do that to them.
