**NEED HELP PLEASE** Installing front 5100's with Eibach Springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aspen432, Mar 1, 2010.
  1. Mar 1, 2010 at 9:53 PM
    aspen432
    aspen432 [OP] Member
    I'm replacing a spacer kit that the previous owner had put on my tacoma and am having an issue that I could really use some help on. I've already removed the old shocks and taken them in to have the new bilsteins assembled with my ebiech springs but something doesn't look quite right. You can see in the "top of shock" attachment that my threads look really long and I'm thinking there is piece missing here. In looking at the attached pdf the "front suspension support sub-assembly" seems to consist of another piece. There was a large 1.5" rubber piece previously (see "with spacer on top of shock") but I think this was part of the spacer kit correct? Is it possible the original sub-assembly was modified when the spacer kit was put on? Any help here would be appreciated as my truck is currently sitting up on jacks in my garage until I can figure this out. Thanks everyone.
  2. Mar 1, 2010 at 10:02 PM
    j1999t
    j1999t Well-Known Member
    Justin
    Northern Colorado
    traded it in
    i think there is supposed to be a pad, and it might be stuck to the spacer, otherwise, check out another tacoma in the area and find out if theirs has a pad...
    someone who knows more about this will chime in soon
  3. Mar 1, 2010 at 10:11 PM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    maybe they put longer bolts to accomodate the spacer lift?
    Im not sure, I went straight to Icon coilovers from stock.:notsure:
  4. Mar 1, 2010 at 10:12 PM
    godofspeed
    godofspeed Washington State.
    2010 4x4 TRD OR DC
    Body Armor front bumper Body Armor rear bumper 17x8.5 Method Bead Lock 35x12.50 Camburg LT Fox coilover All Pro 11 pack leaf Fox rear shock with DSC Allpro frame slider Smittybuilt 9500 winch Cobra CB w/firestick antenna. Hi-lift Smittybuilt air compressor
    Sorry I just reread your post. I was thinking about a diffrent piece. I am not sure, but it does look a little bit longer. Looks like they changed out the bolts to accomodate the spacer lift.
  5. Mar 1, 2010 at 10:17 PM
    aspen432
    You're probably right about them adding longer bolts because all the pictures I've seen show the top with bolts that look about half this length. I'm still unsure about whether there should be a rubber piece somewhere at the top there either underneath the top plate in between it and the spring or on top of the plate in between it and where the top of the shock mounts with the three nuts. Anyone?
  6. Mar 1, 2010 at 10:20 PM
    godofspeed
    2010 4x4 TRD OR DC
    Yes there should be a rubber piece there. Look at the picture of the stock mount, if you look closer you can see a rubber piece that sits between the spring and the actual top mount.
  7. Mar 1, 2010 at 10:21 PM
    godofspeed
    2010 4x4 TRD OR DC
    I think you can leave it the way it is, but the spring squeek would probably annoy me.
  8. Mar 1, 2010 at 10:27 PM
    aspen432
    OK, now that's interesting. I think that I had assumed that that piece was part of the spacer kit needed to get the full 2.5 inches but maybe it was part of the stock configuration. See the attached image. It has the piece that was on top of the plate along with the piece that was under it as well (positioned respectively in the picture). Do you think I should have had them leave the bottom spacer on under the plate? It looks a little thicker than the one in your picture but then again it's not under any compression...
  9. Mar 1, 2010 at 10:30 PM
    godofspeed
    2010 4x4 TRD OR DC
    Yes those actually look thicker. If you put one of those plastic piece between the spring and the top mount, you will be preloading your spring. With that small of a lift I don't think your ride will be that bad. I really wouldn't know because I am using Icon coilover for my lift, vs spacers. I am sure others will chime in.
  10. Mar 1, 2010 at 10:45 PM
    godofspeed
    2010 4x4 TRD OR DC
