Need Help Programming My Tacoma ECU — Stalls After 20 Minutes
Discussion in 'Performance and Tuning' started by Bensmailbox1985, Aug 12, 2025 at 11:36 AM.
  1. Aug 12, 2025 at 11:36 AM
    Bensmailbox1985
    Bensmailbox1985 [OP] New Member
    Benjamin
    2017 Toyota Tacoma TRD Sport 3.5L V6 (2GR-FKS)
    Rough Country Cold Air Intake 10547 JET Performance Powr-Flo Mass Air Flow Sensor #561-69142 RIPP High Performance Coil Packs (SKU # TCP35-6) aFe Power Silver Bullet Throttle Body Spacer #46-38010 MBRP S5338P 3" Cat-Back Single Side Exit Exhaust 6x5.5 Hub Centric Wheel Spacers, 2.00" 6x139.7mm Wheel Spacers, 106.1mm Center Bore with M12x1.5 Studs Cooper discover AT3lt durable tread technology m+s lt265/70R17
    Truck’s Been Down for Over a Month — Need a Tuner’s Brainpower
    I’m in Chattaroy, Washington and I’m stuck on a problem with my 2017 Toyota Tacoma TRD Sport 3.5L V6 that I cannot solve on my own. I’ve tried just about everything I can think of — and I’m willing to pay for someone who can help me get this programmed and running right again.
    Here’s the situation:
    Stock VF Tuner file will not get the truck to run at all — it cranks but never fires and stays running.
    The current tune I have on it will get the truck running for about 20 minutes, then it stalls and dies every time.
    From what I can tell, it’s going into closed-loop fueling after warmup and something in that transition isn’t right.
    This isn’t just about tweaking a few maps — it needs full programming so it will run and stay running without stalling.
    Current Modifications:
    Rough Country Cold Air Intake (Part #10547)
    JET Performance Powr-Flo MAF Sensor (2015–2020 Toyota 3.5L)
    RIPP High Performance Coil Pack System (for 3.5L V6 2GR-FKS)
    aFe Power Silver Bullet Throttle Body Spacer Kit (Part #46-38010)
    MBRP S5338P 3" Cat-Back Single Side Exit Exhaust (Aluminum)
    LT265/70R17 Cooper Discoverer AT3 LT tires (M+S rated)
    2" Hub-Centric Wheel Spacers (6x139.7mm, 106.1mm center bore, M12x1.5 studs)
    Running 92 octane
    What I’ve Tried So Far:
    Multiple VF Tuner tunes, including my own custom files
    Full Mass Airflow Delete (MAF-off) configurations
    Adjusting idle targets, startup fueling, and ignition timing
    Recovery tunes with modified airflow and torque tables
    Open-loop idle setups to prevent stalling after warmup
    Fuel trim and cylinder fuel multiplier adjustments
    Verified hardware: MAF sensor, coil packs, intake system
    Immobilizer resets via Techstream and manual (paperclip) method
    Datalog Symptom Details:
    Truck idles fine after cold start and during warmup
    As coolant temperature approaches ~180–185°F, AFR readings lean out noticeably right before stall
    RPMs begin to drop in steps (small dips) as if airflow is insufficient, followed by a sharp fall
    Once in closed-loop, short-term fuel trims swing heavily, long-term trims begin adapting right before stall
    Stall occurs regardless of load or gear position — even at idle in park
    If anyone here has the experience to help me program this ECU correctly — or knows someone who can — I’d be more than happy to pay for your time.
    Thanks in advance,
    Ben Thompson
  2. Aug 12, 2025 at 3:25 PM
    dave82at
    dave82at Well-Known Member
    David
    Ontario/Canada
    2020 TRD Sport
    Tuned
    Get rid of the RIPP coils, aftermarket intake and MAF sensor. That will solve your issues.
    soggyBottom likes this.
  3. Aug 12, 2025 at 3:28 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Yes, they have some questionable aftermarket parts installed. What was the last thing you modified before you encounter issues?
  4. Aug 12, 2025 at 4:37 PM
    Bensmailbox1985
    Benjamin
    Everything worked perfectly with my mods until I used VF Tuner and it cleared the ECU’s learned memory. After that, everything went downhill.
    I don’t see why I’d need to revert to stock hardware just to make the truck run — it already ran fine with my current setup before VF Tuner wiped those learned values. That tells me the issue isn’t the hardware, it’s the calibration.
    My plan isn’t to go backwards — it’s to calibrate my current mods so they work even better than they did before, without having to remove them just to re-teach the ECU. VF Tuner caused the reset, so I just need to reprogram the tune for my setup.
    If I have to I will put back in my original coil packs but I dont have the original MAF anymore, I have a Delphi MAF just in case.
  5. Aug 12, 2025 at 5:17 PM
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    I’d put $10 that your aftermarket MAF is the entire problem. It’s not reading correctly, causing the ECU to go into closed loop and it dies out as it’s not getting the info it needs to make it run.
    The MAF is the most important sensor for the ECU to control fueling. Put an OEM (in a Toyota box, not from a parts store) MAF in and I bet your truck runs again.
  6. Aug 12, 2025 at 5:35 PM
    Bensmailbox1985
    Benjamin
    Right now I’m running the JET MAF sensor with my cold air intake. I do still have my original coil packs and a Delphi MAF I could swap in, but when I tried the Delphi with the stock tune it still wouldn’t run.
    Since I no longer have the factory intake, that part’s staying. If you think swapping in the Delphi and the OEM coil packs would definitely help, I’ll do it — but if it’s just a guess, then my best option is to keep programming for the setup I have now.
  7. Aug 12, 2025 at 5:51 PM
    Bishop84
    Bishop84 Well-Known Member
    I've seen those coils shut entire banks down. I always start with removing coils like that now.
    Canadian Caber likes this.
  8. Aug 12, 2025 at 5:53 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I agree.
    RIPP coils are JUNK. - Stay away from them.
  9. Aug 12, 2025 at 5:56 PM
    BortisYeltzen
    Barrett
    Salt Lake City, UT
    You need an OEM MAF, and the aftermarket coils are certified garbage. A quick Google search or ChatGPT for the new kids will tell you that. Delphi doesn’t make Toyota MAF’s, at a minimum you need a Denso MAF, but even those are known to not work as well as OEM Toyota MAF’s (made by Denso).
    You bought every snake oil mod known to man. Take them all off. The RC intake is one of the worst “hot air” intakes ever made, the spacer does nothing. If you want performance, it’s honestly really hard to beat OEM.
