need help quick! installing air lift compressor
Discussion in 'Suspension' started by leeland26, Apr 4, 2011.
  1. Apr 4, 2011 at 12:14 PM
    leeland26
    leeland26 [OP] Member
    Lee
    South Louisiana
    05 PreRunner SR5 Long Bed
    Asd we speak, me and a buddy are installing my air lift compressor. We are trying to figure out where the hell we can mount the single gauge inside the cab. The 2nd gen tacos are so damn curvy on the inside that we are having trouble finding a place to mount it:mad:. If anyone has these and found a good way and place to mount them, can you please help a brother out and send me some pics of where you installed them? Thanks!
  2. Apr 4, 2011 at 12:22 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    how big is the gauge? what about the small cubby spot to the right of the steering wheel?
  3. Apr 4, 2011 at 1:01 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    To the left of the steering wheel in the change pocket. Fold it down when you need to see it when filling. Once it's set, close it up and you don't have any gauges visible. Another option, the pillar would be a decent place but I second Tacomaman's response, how big is this gauge you're talking about and how does it mount (surface mount, recessed, etc)?
  4. Apr 4, 2011 at 2:30 PM
    leeland26
    Lee
    South Louisiana
    we tried that but it wont fit. It is too wide! we are going to research tonight and try again tomorrow. Our brains are hurting!
  5. Apr 4, 2011 at 2:36 PM
    leeland26
    Lee
    South Louisiana
    It the gauge is already inside this bracket. the bracket is supposed to mount to under the dash. I will try to post a picture of it later when i can. ill measure it too and give you the dimensions. I tried to put it in the change pocket but if it is too small too. It may work if somehow we could take all of the stuff out of the bracket and mount it by itself but i would have to figure out how. And another problem with that is when you take the change thing out, the fuse box is behind it and i dont want to cover that up. Ill have to look at it a little bit harder bc you are right, that would be an awesome spot to put it.
  6. Apr 4, 2011 at 10:35 PM
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    There is also the drivers side window JB box mount for the supercharger. That is where the supercharger vacuum / boost meter mounts. If you can get one of those mounts you may be able to install it there or just make a new bracket and mount it exactly where you want. Don't forget the right side of the steering wheel change holder or even get a panel mount flush meter instead and then it could be mounted in the center counsel. Lots of options. Just have to figure out a plan.
  7. Apr 5, 2011 at 7:52 AM
    leeland26
    Lee
    South Louisiana
    thanks trap. im going to look into that. I was thinking about just making my own thing. I just dont like the idea of cutting and drilling into my truck. But if its done right, then im ok with that. But i dont always do things right. haha. Im researching it right now. I NEED SOME PICS!! Im going to google it and see if i can get some pics to give me some ideas. If anyone finds any, Please post them! Thanks!
  8. Apr 5, 2011 at 8:02 AM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Moubt it in the middle center counsol
  9. Apr 5, 2011 at 6:00 PM
    Trap
    Indego Ink TRD OR
