need help quick please!! bolt sizes for the stock radio?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RDAY, Aug 27, 2010.
  1. Aug 27, 2010 at 12:38 PM
    RDAY
    RDAY [OP] Well-Known Member
    NY
    07 Tacoma SR5 4x4
    Does anyone know the bolt sizes for the stock radio that holds it in inside the dash. I have lost mine since i started my audio remake and im leaving tomoro and dont want my radio bouncing all around??
    Thanks for the help in advance!
  2. Aug 27, 2010 at 12:47 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    yea i think ur right but idk the length of them?? is there a site i can look at online at the charts?
    Thanks
  3. Aug 27, 2010 at 12:50 PM
    JoshO
    JoshO Well-Known Member
    Josh
    Baltimore MD
    2012 Double Cab 4x4 TRD Sport (Silver)
    Pop a Lock Bolt Codeable Tailgate Lock, Tyger Tonneau Cover, Stubby Antenna, Led Interior Lights, K&N Series 63 CAI, AVS In-Channel Visors. Upcoming Cat-Back Exahust and Lift kit
    Crutchfield.com? They are pretty good with diagrams
  4. Aug 27, 2010 at 1:04 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    i didnt see anything on crutchfield for it its oem toyota bolts is there any schematic sites ne one knows of?
  5. Aug 27, 2010 at 1:14 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    yea the schematics done help me theres 4 10mm but they dont say the length ne one know?
  6. Aug 27, 2010 at 2:08 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    You don't need the bolts. The radio has clips that hold it in snug! 1" long will do just fine!
  7. Aug 27, 2010 at 2:14 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    my last truck only had bolts...i lost all the damn clips!
  8. Aug 27, 2010 at 2:21 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    i believe its a 10 mm head,8mm size1.25 pitch, 8 mm long.you can pic them up at most hardware stores
  9. Aug 27, 2010 at 2:44 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    i just called my dealer and had them order me some i found a couple allen bolts to use temporarily
  10. Aug 27, 2010 at 3:50 PM
    taco084gb
    taco084gb No matter where you go there you are.
    Galen
    NorCal
    They are 8mmx1.25mm thread pitchx 20mm long. I just ordered some. I am actually using metric allen socket headed bolts instead of the 10mm hex head bolts.
  11. May 15, 2025 at 11:57 AM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    An M8 bolt on a Tacoma will accept a 12mm socket. The M8 size refers to the 8mm diameter of the threaded portion not the tool used on it.
    The 4 bolts that fasten the radio take an 8mm socket, but they are probably M6 bolts, and that is the size you will look for when shopping for the bolts.
    Arise from the dead, old thread!
  12. May 16, 2025 at 4:29 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Toyota uses JIS bolts - the head size vs thread size are slightly different for JIS vs common metric, flanges are slightly different too (lots of body and frame bolts are JIS flanged for example).
    There are several suppliers of JIS for reasonable prices and larger hardware aisles also often have them these days.
  13. May 16, 2025 at 11:44 AM
    koco
    Bay Area Ca.
    '01 Taco
    I posted the info about the fastener dimensions because I see many posts on here and elsewhere stating "It's a 14mm bolt" because it takes a 14mm socket etc. Once you start seeking a bolt or a tap, you hopefully realize it is not a 14mm bolt you need.
    Sometimes the JIS fasteners have markings on them to indicate JIS. It's probably best to get some from the junkyard since the dealership will charge many dollars for a nut or bolt.
    deanosaurus[QUOTED] likes this.
  14. Jun 9, 2025 at 3:40 PM
    It’sRainingTacos97
    It’sRainingTacos97 New Member
    1997 Toyota Tacoma Base
    3 inch lift, roof rack
    I went to Advanced Auto Parts. They let me try a bunch of different ones. I have a ‘97 and these M5 - .8 x 12mm Hex Bolts fit and were a total of $5.13 after tax. Hope this helps!
