Need help Ram 2500 first oil change
Discussion in 'General Automotive' started by fireturk41, Jun 17, 2012.
  1. Jun 17, 2012 at 8:05 PM
    fireturk41
    fireturk41 [OP] I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    I tried my first oil change today...i swear the incredible hulk works for Ram...how the heck did you get your filters off the first time? Ive tried all kinds of filter wrenches in fact i gotta go by advance auto to return two I broke, ive tried the screw driver trick to no avail the filter will not even budge, its battered bruised and punctured but still cant get it off. so the truck is sitting in the driveway with an unbudge able filter, not even an inch! how the heck do you get these darn suckers off for the first oil change!
    anyone on tw have any suggestions?
  2. Jun 17, 2012 at 8:10 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Typical.
    Kawasaki hired the same gorilla to install the filters on their motorcycles.
  3. Jun 17, 2012 at 8:13 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    drill a hole through it and then use a piece of rebar to get the leverage you need?
  4. Jun 17, 2012 at 8:15 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    i dont think i have the room for the rebar, and ive tried channel lock style wrenches just mutilating the filter
  5. Jun 17, 2012 at 8:16 PM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    a large flathead screwdriver and a hammer does the trick too
    toyota had the same gorilla put a filter on my truck too.
  6. Jun 17, 2012 at 8:19 PM
    300rem7
    300rem7 Well-Known Member
    Arlington, Texas
    2011 TRD Offroad 4x4
  7. Jun 17, 2012 at 8:20 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
  8. Jun 17, 2012 at 8:23 PM
    jgwheeler17
    NC
    neglect, mostly.
    hmmm. . . . stupid question, but have you sprayed some liquid wrench or wd40 up towards the threads? . . . .but im out of ideas. maybe use temperature as a variable. somehow get the filter cold which will cause it to shrink? . . ok that sounds stupid just reading it. :eek: i don't know man.
    yeah i know, he said he tried that. . . was just trying to think of someway to get him more leverage. though im not real sure where the filters are on those trucks.
  9. Jun 17, 2012 at 8:23 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Use a flat head screw driver and a hammer, or a really long punch with a sharp edge or chisel, and beat it off from the lip. Use it to drive it around at an angle, don't punch through it.
  10. Jun 17, 2012 at 8:58 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    its about on the same locations as the 3.4s except upside down from the top of the block
  11. Jun 18, 2012 at 5:36 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
  12. Jun 18, 2012 at 9:53 AM
    jgwheeler17
    NC
    neglect, mostly.
    still nothin?
  13. Jun 18, 2012 at 10:30 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Worst case, I'd tear off the outter metal casing so I could get a flat head on the heavier base metal and try to hammer it loose that way.
    If you get the outter casing off, you should be able to get a flathead or a center punch on the holes and hammer it around. Be careful though, you don't want to bend the threaded part otherwise you're really up shit's creek. Maybe try a little heat on the threaded part if you tear apart the casing? :notsure:
    I haven't tried this method, just throwing it out there because it seems like you are running out of ideas.
  14. Jun 18, 2012 at 10:35 AM
    TacomaBiff
    TacomaBiff Well-Known Member
    Co
    TRD 4X4
    Wife said Hell NO
    Buy a new truck.
  15. Jun 25, 2012 at 6:07 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    You get it done? You try a screw driver and tapping it sideways like I said?
  16. Jun 25, 2012 at 6:48 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Strap wrench is the best bet here man. Don't buy a junky one. Get a good one and it'll get you through.
    Get near the base of the filter where it meets the block/mounting point and muscle it.
    I ain't like Shemicals, but I've never met an oil filter that I couldn't get off yet.
  17. Jun 25, 2012 at 10:31 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I would have suggested maybe bringing the vehicle to operating temperature and trying to take it off with the metal having expanded a bit but I guess that's really out of the question now.
  18. Jun 25, 2012 at 10:34 PM
    Harleyfx69
    Harleyfx69 Well-Known Member
    They make a special wrench for cummins equipped dodge trucks..
    It clamps on really tight and holds well,
    It also helps to take the passenger side battery out or at least move it to get to it,
    Also be careful taking the drain plug out they can strip, i need to get anew one before i do my next one because it doesnt have much turns left in it ..
  19. Jun 27, 2012 at 8:18 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    courtesy of Ram the truck got towed to the dealership after I told them what went down. The ill tempered something complained that I brought the truck back until I told her that they are going to change my oil using my oil, she argued and i looked at the service manager and he said they can ring up the free oil change using my oil. she whined about how its not her fault because nobody taught her how to ring up an oil change with the customer bringing in their own oil and stormed off. about an hour after they pulled the truck in the bay the manager calls me in the middle of happy time with my girl that the truck is done...we ride up their and he tells me everythings finished and that they need to put the oil in but the tech went to break, I asked if another tech can put it in he said all of them are at lunch, I asked if he can put it in he said no, I asked if I could put it in, I again got a no. 2 hours later I get another call that the truck is done but that I no longer have a powertrain warranty. I brought up Magnusson Moss and was sent on my way by the dealership. I called up Ram, got confirmation that my warranty will not be voided and they advised me to keep oil change records and have the dealer sign off that all my oil bottles are sealed before service and if I am to have any warranty issues in the future call Ram before the dealership and present the case number and they will take care of everything
    I hope I never have to take the truck back and thank got the filter that was cranked on there at the factory is finally off
    thanks for all your help!
    Im thinking bout adding a bypass filter to help with soot accumulation in the oil, but i hafta speak with corperate first to make sure it wont void the warranty lol
  20. Jun 27, 2012 at 8:28 AM
    aznutx
    aznutx Well-Known Member
    DFW Texas
    2011 White TRD
    grats you got the problem solved, and sorry for yet another dick dealership, it's really hard to find a good one these days
