Need Help. Randomly won't start
Discussion in '1st Gen. Tacomas (1995-2004)' started by ahum12, May 19, 2015.
  1. May 19, 2015 at 10:47 AM
    ahum12
    ahum12 [OP] Member
    Aaron
    Madison, WI
    96 Tacoma 4x4
    A couple months ago my manual 96 2.7L 4 cyl. started to randomly not start. Most of the time it would start just fine, other times it would just make a clicking/buzzing sound and never turn over. Took it to my cousins shop, he couldn't get the problem to happen to him so he just replaced the starter based on what I told him. Worked great until this past Sunday it did it again. Has nothing to do with the battery, radio and everything comes on if I leave key in on position. Tried using the clutch cancel start, still same problem.
    When it first started doing this, I could let it sit for a minute to an hour after not starting and try again, and it would start right up and run perfectly normal.
    It's going back to my cousins shop tomorrow. Just looking to see if anyone knows exactly what is wrong or has the same problem. Any help is much appreciated.
  2. May 19, 2015 at 10:57 AM
    lanestaco
    lanestaco Well-Known Member
    Lane
    Guthrie, OK
    '13 Tacoma TRD Sport 4x4
    Ignition?
  3. May 19, 2015 at 11:05 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Replace the battery cables. They may look fine but if you peel the insulation off I bet they are corroded. The positive side goes straight to the starter, and wraps around the front of the oil pan in a plastic wire loom. Removing the skid plate will make this a fairly easy job. Replace the ground cable as well.
  4. May 19, 2015 at 11:19 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    ^^^ this sounds like a bad connection. just because the radio works doesn't mean there isn't some kind of issue with battery. it is under much more load when you try to start the car. id clean terminals and connections and rre tighten, if that doesn't work replace the cables
  5. May 20, 2015 at 11:30 AM
    ahum12
    ahum12 [OP] Member
    Aaron
    Madison, WI
    96 Tacoma 4x4
    Found out the ground wire was loose, which explains the buzzing sound from the electricity working its way backwards.
    Thanks for the advice
