Need help, re-gearing
Discussion in 'Performance and Tuning' started by teddygrahams, Jun 12, 2011.
  1. Jun 12, 2011 at 6:54 PM
    teddygrahams
    teddygrahams [OP] Well-Known Member
    Hey i have a tacoma full long travel front and rear with headers, cold air, and exhaust. I currently have 33s and rockin the 2.7L. I have a factory toyota e-locker. My trucks sluggish goin up hills and pretty much just crusin.
    Please dont waste my time or yours if you are a noob and just read forums all day to get your info.
    Id like to know from people with experience what gear ratio i should move up to.
    much appreciated and thank you
  2. Jun 12, 2011 at 6:55 PM
    teddygrahams
    the tires are all terrains fyi, for weight info bfgs
  3. Jun 12, 2011 at 6:55 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    If you do not plan on getting larger than 33" tires stick with 4.56 otherwise if you are going to go with 35's go with 4.88's.
  4. Jun 12, 2011 at 7:09 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    I have the 2.7 with 33"x12.3" BFG MTs. I have 4.88 gears and I wouldn't have it any other way. 4.56 is good for commuting but if you wanna be a man and tear shit up hardcore go with 4.88s.
    I also have a CAI, header, and exhaust - check out my build page below if you want.
  5. Jun 12, 2011 at 7:11 PM
    especk
    Erik
    Redding, CA
    i wanna see pics of ur truck btw. u rockin a reg cab?
  6. Jun 12, 2011 at 7:14 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    X2
  7. Jun 12, 2011 at 7:24 PM
    rcfreak201
    rcfreak201 Well-Known Member
    i have a DCLB with 33s and i put 4.88s, i wouldve gone with 4.56s but i know i will be getting 35s in a few months so no need to do it twice, ill live with the higher gear ratio for a while
  8. Jun 12, 2011 at 7:55 PM
    especk
    Erik
    Redding, CA
    plus ur a v6 right?
  9. Jun 12, 2011 at 7:58 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    How much would it cost to re-gear?
  10. Jun 12, 2011 at 7:59 PM
    JayARRGHH
    JayARRGHH Well-Known Member
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    285/75/R16 Eldarado MTZ, Alpine CDE-102 Deck, DIY Snorkel, 2" Spacer Lift, Uniden Bearcat 880 CB, Custom over head console w/ map lights, CB Mount, and external CB speaker, 2 12" Kenwood Subwoofers, 300 Watt Alpine Amp, Alpine 3" lift 500# capacity
    I don't mean to thread jack this or repost, but is it bad to regear to say 4.88 if you don't have bigger tires?
  11. Jun 12, 2011 at 8:04 PM
    especk
    Erik
    Redding, CA
    it will be about 700-900 per axle (that includes parts and labor). If you can do some of the work yourelf or if you got a hookup, it will be less
    i would only recommend it if you are living in the mountains or going up hills all the time or if you doing a lot of four wheel or if your drag racing.
  12. Jun 13, 2011 at 6:06 PM
    teddygrahams
    sweet thanks man
  13. Jun 13, 2011 at 6:17 PM
    teddygrahams
    im rocking the 4.56 with an elocker right now and i have header, cold air, and exhaust and that thing is havin trouble with hills and what now.
  14. Jun 13, 2011 at 6:18 PM
    rcfreak201
    yeah im a v6
    it costed me 300 but im a prerunner so i only have the rear axel
