Need help: Recommendations on a 6" suspension lift...
Discussion in 'Suspension' started by vprgts, Jun 30, 2011.
  1. Jun 30, 2011 at 3:17 PM
    vprgts
    vprgts [OP] Well-Known Member
    Walter
    Centreville, VA
    Tacoma TRD Off Road Hybrid
    285/70/17 Nitto Ridge Grapplers, RRW wheels 17 x 8.5, Wescott designs pre collar lift, rough country power side steps, Truxedo pro x15 soft roll up bed cover, OEM bed mat, OEM bed swing out box, OEM Trd pro front skid plate, aftermarket pro grill, diode dynamics led fog lights, OEM sport hood, PPF and tint,
    I'm really interested in lifting my 2010 sport Trd double cab 4x4 auto but cannot decide on which system??
    Here are my driving characteristics. Primarily a to and from work truck with very little four wheeling (here and there) and the occasional winter snow. I don't really do any towing unless I'm moving light stuff. So you can see that I guess it's more about the show and ride.
    I want to toss 20x10 Ultra Goliath Wheels with 35x12.50 r20 Nitto Terra Graplers on. (Are these good tires?)
    Sure this is a pretty expensive outfit but any suggestions would be appreciated.
    Thanks!
  2. Jun 30, 2011 at 5:05 PM
    DA INFERNO
    DA INFERNO Member
    Fresno, Ca
    11' 4x4 Double Cab TRD
    Nitto's are very road noisy. The Toyo MTs are much quieter and ride very nice. I had 35" Toyo's on my 2500hd Diesel and loved them. Sorry I cant help you on the Tacoma lift, I'm learning about Tacoma lifts myself. If it was a Chevy, that's easy I would say go with Cognito!
  3. Jun 30, 2011 at 5:27 PM
    vprgts
    Walter
    Centreville, VA
    Thanks for the heads up on that. I will check em out.
  4. Jun 30, 2011 at 5:29 PM
    vprgts
    Walter
    Centreville, VA
    Good info. It looks as if it's either going to be fabtech or pro comp for this 6 inch build. Thanks again!
  5. Jun 30, 2011 at 5:31 PM
    Manwithoutaplan
    ID
    Some with 6 inch pro comp lift. I would recommend getting the lift with the coil over instead of the spacer. ALso recommend getting the drop down bracket from beef taco. On the tire question, i have heard great things about the Nitto Terra Graplers. Make sure if you get the coil over lift to adjust the coil so it is not to stiff.
  6. Jun 30, 2011 at 5:33 PM
    Manwithoutaplan
    ID
    Also not matter what lift you go with your going to get the drive shaft vibes. unless you get a single drive shaft.
  7. Jul 1, 2011 at 8:02 AM
    93civEJ1
    93civEJ1 Well-Known Member
    09 DC TRD OR
    Procomp 6" Stage 1, Bilstein 5100's in front, flowmaster 40 series
    i have a 6" pro-comp on the way for my 09. I will be going from a 3". I just went with the basic kit for now since I dont do very much off road and its mainly highway driving.
  8. Jul 1, 2011 at 8:30 AM
    MR.Redtaco
    MR.Redtaco Active Member
    Wilson NC
    06 4x4 SR5 lifted
    6in fabtech lift, 20in xd rims, K&N air intake, 35in tires
    I have the fabtech basic 6in lift with 35 trail's the ride isn't to bad it is a good quality lift. I had the terra grapplers on my f150 and they didn't last very long but that was because it was on a heaver truck. They are a great a't and do well off road.
  9. Jul 5, 2011 at 5:46 PM
    vprgts
    Walter
    Centreville, VA
    I'm not sure what you mean in regards to the drive shaft vibes. Doesn't the truck already come with a single drive shaft? Forgive me if this is a dumb question. Also do I need a steering stabilzer on the pro comp suspension lift?
  10. Jul 5, 2011 at 5:53 PM
    vprgts
    Walter
    Centreville, VA
    thanks for that info! so i've decided to go with the pro comp stage 1 kit bc of the good things i've heard and the cost. my question is can I shove a 20 x 10 rim under the 6" lift? 4wheelonline says this, "Stage I systems are available with spacers for the factory front struts and ES9000 rear shock absorbers to deliver factory ride quality. 6” of lift allows the use of 35” x 12.50” tires on 18” or larger diameter rims up to 9” wide with up to 4.75” backspacing."
  11. Jul 5, 2011 at 5:55 PM
    vprgts
    Walter
    Centreville, VA
    Thanks for that explanation! I'm planning on buying all the items at 4wheelonline...Do they offer single drive shafts? What name brand can you recommend? Thanks!
  12. Jul 6, 2011 at 8:39 PM
    lvlytaco
    lvlytaco Well-Known Member
    Allan
    Hawaii
    Got Lip?
    6" procomp basic lift, alpine dbl din, 9" headrest screens, mb quart components, jl amp, yellow top battery, wet okole seat covers all around
    u can fit 20x10 easily, ive got 20x12 on mine....
