Need help removing 1st gen door panel.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Leadgolem, Sep 26, 2010.
  1. Sep 26, 2010 at 4:50 PM
    Leadgolem
    Leadgolem [OP] Well-Known Member
    Greg
    Littleton, CO
    98 Tacoma SR5 2.7L 4x4 stick
    Herculiner bed liner, White LED instrument lights, Custom painted hood, Homemade leather steering wheel wrap, Avic u310bt gps stereo, 1.5" bushwacker fender flares, 1.25" bilstein lift front, 1" shackle lift rear, rear bilstein 5100 shocks, ridiculous helper spring lift rear, wet okole seat covers, mutilated exhaust, boom mat under hood
    Ok, so I'm trying to get the door panel for my 98 off. I've got it almost all the way off, but I can't seem to get the panel off the door latch. Uh, help? I don't want to break it trying to take it off.
  2. Sep 26, 2010 at 5:55 PM
    Leadgolem
    Greg
    Littleton, CO
    Ok, here are some pics so you'll know what I'm talking about. The first one has a nice red arrow pointing to the sticking bit. Second one shows I have all the clips around the panel out.
  3. Sep 26, 2010 at 6:10 PM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    right behind the lever to open the door, you will see a black phillips head screw, remove the screw, then remove the square back piece behind the lever, you will need to pull the lever as if you are opening the door. The square piece should come out. Good Luck Bro!
  4. Sep 26, 2010 at 6:16 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2010 Double cab 4X4 TRD Sport with JBL
    Redline Tuning hood struts, tinted windows, FX-R HID projector retrofit headlights, AMP power steps
    Yeah, what he said. The red arrow that you have is pointing to a screw. Remove it.
  5. Sep 26, 2010 at 6:46 PM
    Leadgolem
    Greg
    Littleton, CO
    Sorry, I'm really not seeing what you mean. I already took the screw out. Sorry about the crappy pic, but it is night here.
  6. Sep 26, 2010 at 6:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  7. Sep 26, 2010 at 6:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  8. Sep 26, 2010 at 7:01 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    ok, now slide the whole square thing either forward or back (I don't remember) then out away from the door.
  9. Sep 26, 2010 at 7:08 PM
    Leadgolem
    Greg
    Littleton, CO
    Got it! Thanks guys, I kept thinking I needed to pull on the actual door handle. :)
