Need help removing center console
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lasllc, Jul 31, 2009.
  1. Jul 31, 2009 at 5:03 PM
    lasllc
    lasllc [OP] Wait. . what’s wrong here
    Southwest RedRocks
    13 SuperWhite DCSB Sport TRD
    SnugTop Super Sport, BedRug mat, Redline Tuning hood lifts, LED interior lights, 3D carpet protectors.
    Installing my just arrived WO covers and really need to remove the back half of the center console; In order to get the plastic cover off the sealt belt latch so I can route the strap up and over the seat frame. With the console out it will be much easier
    09 TRD AC MAN TRANS; I have the cup holder panel off and the rear panel off and the two screws at the top front where the front and rear sections join. I can see that the back half needs to come up and back to release the 2 pins on each side at the joint BUT THERE IS SOMETHING ELSE I CAN NOT FIGURE OUT that is holding it.
    A little help please . . .
  2. Jul 31, 2009 at 8:00 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    Pull up the carpet in the bottom of the console. It is not glued down. There are two bolts under there.
    Once they are removed. The console easily pulls rearward.
  3. Aug 1, 2009 at 6:23 AM
    lasllc
    Southwest RedRocks
    Thanks COUPE.
    I had pulled at it several times and it appeared to be glued down, but I know that had to be it ,finally got ahold of the fuzz and just thru caution to the winds; I was being to gentle
