need help removing dash power plug....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dessertsand05, Oct 18, 2011.
  1. Oct 18, 2011 at 2:13 PM
    dessertsand05
    dessertsand05 [OP] Well-Known Member
    Boston
    05 Tacoma DC SR5 4x4
    Working on it
    The cover on the power port in my 2005 tacoma broke off. I got another part, and it looks like it just plugs in, but have to remove the old one.
    Anyone know the best way to remove the small power plug next to the ciraette lighter?
    I am afraid of braking the dash taking it out, must be a trick to do this....
  2. Oct 19, 2011 at 5:36 PM
    blacktaco07
    blacktaco07 Active Member
    Canada
    2007 4DR Tacoma TRD
    All you have to do is:
    Grab a hold of it with you finger pull out and turn at the same time. Normally you have to turn 1/4 to 1/3 of a turn and it will come out.
    Place your figer inside for some leverage!!!!No smart A** comments here!!!
    Good luck
  3. Oct 20, 2011 at 8:17 AM
    dessertsand05
    Boston
    Working on it
    No way, the thing is not budging.......my fingers are raw. Busted out the pliers, it doesn't move.
    Any tutorials on taking your whole dash apart :-(
  4. Oct 20, 2011 at 11:49 AM
    dessertsand05
    Boston
    Working on it
    I got it out with a lot of force, there is a trick to this.!!!!!
    There are two small plastic tabs that hold it in place. Like the cigaratte lighter; the 12v plug is made up of the plastic housing and a metal socket. Once the metal socket is slid in, the tabs in plastic housing will no longer bend in to allow removal. You must remove the metal socket barrel first!!!!
    1.) You have to somehow find/feel where another tab that locks the metal socket to the plastic housing.
    2.) Remove the metal socket
    3,) then the plastic sleeve slides right out.
    Way easier said than done, hopefully this will help save someones dash.....
    Lower dash is scratched up and hole the plug is inserted into got a little messed up, atleast I don't have to look at a broken 12v plug anymore.
    MrPunktoyou and jkuniverse like this.
  5. Feb 28, 2015 at 1:25 PM
    nlic1995
    nlic1995 New Member
    Mark
    Somerset, MA
    05 TRD Sport
    I just changed my power outlet cover in my 05 Tacoma. Look inside the metal barrel. At approximately the 11:00 posistion you will see a small plastic tab sticking into the metal barrel. Carefully break it with a small screwdriver. It's okay to break it as long as you are replacing the cover / plastic barrel, as it is part of the cover / plastic barrel assy. After breaking the tab carefully pull the metal barrel straight out. You may need to pry it with a screwdriver to get it started and perhaps use two pairs of plyers to pull it out. Be careful there is an electrical plug connected to the back of it. Once you have it out and disconnected from the plug. Use the small screwdriver to pry / break the two plastic tabs holding the cover / plastic barrel in place. They are at 3:00 and 9:00. Once the two tabs are broken, the cover / plastic barrel will slide right out. Reverse for installation.
    apbright likes this.
  6. Feb 28, 2015 at 1:30 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    this thread is 3 years old lol but good info on how to remove it :thumbsup:
    MrPunktoyou and tbird95 like this.
  7. Oct 25, 2016 at 9:42 AM
    MD_Taco_Owner
    MD_Taco_Owner Member
    Jay
    Stock 2007 Pre-Runner, 4-door, V6
    None
    Good information is always appreciated. I have to do this myself on my truck to tap the power lugs on the back for a satellite radio and a USB rocker switch installation. One side will be used to power the satellite radio the other will go to power the USB charging port/rocker switch since they both have fuses somewhere in there. :oldglory:
  8. Mar 14, 2017 at 8:21 AM
    Drakken
    Drakken Well-Known Member
    Tennessee
    Silver Streak Mica 2006 AC 4X4
    Bump for an old thread. Just did this today to replace the plastic barrel that was broken in mine. Took a few minutes but worked great.
  9. Aug 25, 2018 at 6:54 PM
    tbird95
    tbird95 Well-Known Member
    British Columbia, Canada
    TRD sport SR5 V6 DC, LB, 4x4, Tow package
    4runner heated, signal, courtesy light side mirrors, rearview mirror w/compass, temp & backup cam w/ pop luck PL 5400, Interior lights/gauges, BHLM, grillcraft MX black. Third brake light LED swap, rear tail lights LED swap from 2011. 3" Toytec (Boss) Coil overs, rear TSB AAL Bilsteins, Light Racing UCA. TRD grill badge, VIPER Smart Start.
    Bump odie but goodie
  10. Sep 13, 2019 at 10:45 PM
    Truckrider
    Truckrider Your truck is your armor in this world.
    Tony
    Los Angeles CA
    2000 PreRunner 3.4L 2WD
    Proof that good info is ageless. Thanks for this.
  11. Jan 4, 2020 at 12:43 PM
    jkuniverse
    jkuniverse Well-Known Member
    Arlington TX
    2013 Limited DCSB 4x4 Super White
    Good info. Used it to pull the 12v accessory socket
  12. Jan 4, 2020 at 6:38 PM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Must be a normal problem, the little tabs that hold mine in the dash were broke, whole thing just slid in & out. Little plastic sleeve & cover from e-bay $13.00 + 10 minutes, all back to normal.
  13. Sep 3, 2020 at 7:31 PM
    MrPunktoyou
    MrPunktoyou New Member
    Dave
    Lansdowne, PA
    2006 Tacoma 4-dr 4x4
    And five years after that, I too am thankful for this info.
