Need help removing leaf springs
Discussion in '1st Gen. Tacomas (1995-2004)' started by 19tacoma98, Feb 4, 2009.
  1. Feb 4, 2009 at 9:59 PM
    19tacoma98
    19tacoma98 [OP] Member
    Rocky Mount, NC
    98 V6 Ext. Cab SR5 TRD
    3" Body lift Sound system wheels and tires 2" leveling kit window tint Enjin cold air intake aftermarket lights
    My truck is on jack stands, and i am trying to remove my stock leaf springs off of my 98 4x4 tacoma but i can not get the springs to come off of the shackle. the inside plate is off but the leaf will not slide out...any advice?
    :help:
    Thank you
  2. Feb 4, 2009 at 10:02 PM
    mneuls
    mneuls Well-Known Member
    Fort St John, British Columbia, Canada
    5100's and dakar leaf 3"lift, Satoshi grill,
    Bilstein 5100's front and back, dakar 3" leaf springs, Westin bull bar, piaa driving lights, piaa replacement bulbs, H/U, 2x10" mtx tt65 subs, 1000w clarion monoblock, Mtx surround speakers. green wire mod. Flowmaster 40, airaid intake. scanguage II.
  3. Feb 4, 2009 at 10:04 PM
    19tacoma98
    Rocky Mount, NC
    sorry for not having a pic, but iv tried the hammer, didnt budge
  4. Feb 4, 2009 at 10:08 PM
    mneuls
    lots of wd40 might do the trick. I like to use "nuts off"
  5. Feb 4, 2009 at 10:08 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Ohhhh yeah...I can remember those days. It ain't fun.....
    The metal sleeve in the bushing is probably fused to the shackle.
    Have you sprayed the area with penetrating lubricant? (PB blaster)
    Spray it and spray it some more and let it soak, and spray it some more. If you're really LUCKY, that'll help.
    On my old 96 - I had to get a spring shop to torch the stuff off. Ultimately, it destroys the bushings in the process.
  6. Feb 4, 2009 at 10:10 PM
    19tacoma98
    Rocky Mount, NC
    iv tried that too man, nothing..i swear its welded on there or im just doing something totally wrong, should just slide off to the inside am i right?
    iv only tried WD 40 does something work better for this?
  7. Feb 4, 2009 at 10:11 PM
    6shooter
    6shooter Well-Known Member
    portland, or
    06 sport........
    plenty.......
    post up a pic of what you're working with here
  8. Feb 4, 2009 at 10:15 PM
    mneuls
    If you can get your hands on some kroil, that would be the best. "It's the only oil that creeps"
  9. Feb 4, 2009 at 10:19 PM
    19tacoma98
    Rocky Mount, NC
    i know this is a terrible pic but its the best one i have for right now
    right behide the pipe is the shackle, i have the nuts off of the shackle and the inside plate removed, but the leaf wont come out
  10. Feb 4, 2009 at 10:20 PM
    19tacoma98
    Rocky Mount, NC
    is it hard to find?
  11. Feb 4, 2009 at 10:23 PM
    mneuls
    it's easy if you do industrial work. i've never seen it at napa. you could try pounding a wedge shaped piece of wood in there, it's worked for me before.
  12. Feb 4, 2009 at 10:43 PM
    Janster
    Jandy
    Lancaster, PA
    Just in case you're not familiar with what the shackles look like....
    You already removed the plate. The other parts of the shackle are all-one-piece (like C shaped).
    What happens, is the metal sleeve inside the bushing will rust/fuse to the shackle pin making it nearly impossible to remove. If you've tried PB BLaster or Kroil and let it soak for atleast an hour (or days)....
    You might need to torch the stuff off and/or CUT the shackle.
  13. Feb 5, 2009 at 9:21 AM
    19tacoma98
    Rocky Mount, NC
    okay i will try the PB blaster today but i cant afford to cut the shackles, then i would have nothing to drive until the new ones came in and i cant afford them right now
  14. Feb 5, 2009 at 10:03 AM
    98tacoma27
    Ben
    Not Beech Creek
    Crow bar. You may need to lift the truck up some more. It could be bound.
  15. Feb 5, 2009 at 11:01 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Janster is 100%. There is a good chance that you will have to use a torch to get it off.
  16. Feb 5, 2009 at 11:06 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    If you lack a torch, use a sawzall and get to cutting between the leaf and the shackle. I went through this same thing on an old Mustang years ago. You're not alone! :)
  17. Feb 5, 2009 at 4:15 PM
    Ry1984
    Ry1984 Well-Known Member
    From Texas, Now Miami FL
    01' ExtCab SR5 2.7 4x4
    K&N FIPK, Billy 5100 all around, 881's in the front, Toytec AAL
    try freezing it and knocking it out with hammer. computer duster will work
  18. Feb 5, 2009 at 4:17 PM
    Ry1984
    hard to tell by that pic whats going on but just trying to through anything out there before you have to go to torching or something to that extent
  19. Feb 5, 2009 at 4:25 PM
    19tacoma98
    Rocky Mount, NC
    here is a better pic of the situation if it helps
  20. Feb 5, 2009 at 4:33 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    definitely gonna need new eye bolts..............and if the shackles are bad...replace them too. when i put in my new springs back in the summer.............i had to cut/ torch the springs/bolts to remove them..................the bushing sleeve was rusted solid to the bushing. it wasnt fun by any means. if you can get new bolts................just cut them springs/bolts outta the way.
