Need help removing leaf springs
Discussion in '1st Gen. Tacomas (1995-2004)' started by 19tacoma98, Feb 4, 2009.
  1. Feb 5, 2009 at 8:25 PM
    19tacoma98
    19tacoma98 [OP] Member
    Rocky Mount, NC
    98 V6 Ext. Cab SR5 TRD
    3" Body lift Sound system wheels and tires 2" leveling kit window tint Enjin cold air intake aftermarket lights
    so if i torch them off what all kind of parts will i need to buy? how expensive is this going to be?
  2. Feb 5, 2009 at 8:28 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    lets see............you will need the main eye bolts, and the new springs should already come with new bushings.........................and if your shackles are still in good shape.................all you should need is the main eye bolts and new nuts. and if i were you.....do as i did and put some anti-seize on the bolts so they dont rust. i dont have any pics of my suspension swap..........................but it was messy as hell. caught the frame on fire right by the gas tank.......................knew it was gonna happen to, so i had a hose nearby.
  3. Feb 5, 2009 at 8:35 PM
    19tacoma98
    Rocky Mount, NC
    Where can i get main eye bolts and new nuts from? i cant just use any old bolts can i? how much do new shackles run? i cant find any junkyards that have them
  4. Feb 5, 2009 at 8:39 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    unless you wanna order online........................get them from the local toyota dealership, or try autozone or pepboys. and no..........not just any bolt will work. if you wanna order online.......................get them here..... great prices for shackles and main eye bolts, and customer service is awesome too. only thing is..............they are closed on friday.
  5. Feb 5, 2009 at 8:54 PM
    19tacoma98
    Rocky Mount, NC
  6. Feb 6, 2009 at 3:52 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  7. Feb 6, 2009 at 5:18 AM
    98tacoma27
    Ben
    Not Beech Creek
    I would try something like this (ball forks) before you cut something.
  8. Feb 6, 2009 at 6:17 PM
    19tacoma98
    Rocky Mount, NC
    okay, thanks for all the help. i just put it back together, i guess ill just try again when i have the equipment to try it again
  9. Feb 6, 2009 at 7:24 PM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    Drive with them on! Theyll come right off!
  10. Feb 6, 2009 at 7:25 PM
    Hambone155
    omaha
    DRIVE WITH THEM ON! THEYLL COME RIGHT OFF! UNLESS your trying to save thouse shackels....................
  11. Feb 6, 2009 at 7:25 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    If its stuck, the bushing is shot. Torch the sumbitch off.
  12. Feb 8, 2009 at 1:03 PM
    nelson76
    nelson76 Member
    Rhode Island
    2008 access cab
    I just did mine on my 98 2 months ago, i had the same problem, what i did was take the whole leafspring off with the shackle still on it,lube the hell out of it with wd40 or whatever you've got,heat the hell out of the shackle right at the bushing,eventually the rubber will burn,melt away,step on the shackle while it's flat on the ground push the spring down so that it spins on the shackle and you can slide the shackle right off,that's how mine came off but then i had the metal sleeve still frozen on the shackle bolt so i torched the hell out of that and spun it with some channel lock pumps while heating it,it'll get red and smoke but as long as your patience doesn't run out you can get it done,i'm in RI and mine's been through 10 winters and i reused every original part,it's is easier and quicker to buy new parts but if you don't want to spend money it is possible.
  13. Feb 9, 2009 at 5:40 PM
    Jentry
    Jentry Active Member
    Brigham City, UT
    96 Tacoma SR5
    K&N Air Filter, Airaid Throttle Body Spacer.
    I just replaced my leaf springs on my 96 tacoma last weekend. I used a air hammer and put the chisel in between the shackle and the spring it self. it should come right off. if not a little heat and beat. good luck man!
