Need help removing my oil filter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nOLd, May 7, 2011.
  1. May 7, 2011 at 11:12 PM
    nOLd
    nOLd [OP] Well-Known Member
    nold
    Dallas
    I'm doing my 5000 miles oil change and I'm having issues removing the old oil filter. it seems really tight. I tried the socket and straps to remove it and no avail. I appreciate your advice
    Thank you,
  2. May 7, 2011 at 11:12 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    Worst comes to worst, jab a screw driver in there and turn
    no but really, try taking it out while its warm
  3. May 7, 2011 at 11:14 PM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    Yeah.. stick it right through the middle and your good
  4. May 7, 2011 at 11:14 PM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    counter-clockwise with an oil filter wrench
  5. May 7, 2011 at 11:18 PM
    JHAirForce05
    JHAirForce05 I'm kinda a big deal
    Justin
    Tacoma, WA
    09 DC LB SP
    Kenwood DDX712 with Nav and rear view cam, Viper 5901 Security System, Kobalt Slim Line Compact Truck Tool Box
    Plumbers pliers! Had to use them on my boats oil filter
  6. May 7, 2011 at 11:21 PM
    acmair
    acmair Well-Known Member
    Andrew
    '10 BSP PreRunner Dbl Cab Short Bed SR5
    It was hard removing mine too the first time. Just keep going at it, sometimes it seems like its rubbery, right? You force it with the socket and instead of the filter moving, its the wrench. Or maybe that was just mine... but just keep at it and force it, it'll let go. Worst comes to worst you dent an old oil filter that you are replacing anyway. Just be careful.
  7. May 7, 2011 at 11:22 PM
    nOLd
    nold
    Dallas
    Thanks guys for the quick response. I will try all your advice...
    Thanks again
  8. May 7, 2011 at 11:25 PM
    nOLd
    nold
    Dallas
    Thanks man... its to the left right when you turn? just want to make sure :)
  9. May 7, 2011 at 11:27 PM
    acmair
    Andrew
    Yeah, it's counter clockwise. Toward the driver's side. :)
  10. May 8, 2011 at 1:30 AM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    When I worked in the forklift shop at a minerals processing plant the old timer there shared a tip with me. As long as the surface is clean and you lube the oring you really don't need to tighten the filter on there so tight you can't get it off without a tool. In other words, in the hundreds of filters I've put on, I've done them all snug by hand, and can take them off by hand, and none have leaked. As with everything use your intuition and sense to determine how tight you need it.
    That being said, if you can't get it off with an oil filter wrench you might try channel locks, failing that try a pipe wrench, failing that get a screw driver or chisel and tap at the base, angling the tool so you're basically turning it as you tap. Failing that, punch a thick screw driver through the middle of the oil filter side ways and try to turn it. Failing that seek help.
  11. May 8, 2011 at 1:44 AM
    onesixseven
    onesixseven Well-Known Member
    Tyler
    Santa Clarita California
    02 Prerunner SR5
    3.5" Kind Coilovers Total Chaos UCA's 31" BFG A/T's 8000k hi/lo HID kit Flowmaster Super 44 5% tint all around exterior LED's Deck Plate Mod bedlined flares debadged Full Fosgate/JL Audio Stereo
    x2, a screw driver is how i got mine out the first time i changed it
  12. May 8, 2011 at 1:51 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I think I used a 30 year old snap-on band filter...the clearance for filter pliers wasn't that good. Now I have filter wrench that slips on the back and has three fingers that tighten as you turn...very handy when the back of the filter is easiest to get to.
    Howard
  13. May 8, 2011 at 5:07 AM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    i had to use one of those band oil filter wrenches to get the factory filter off. dented the hell outta the filter but it finally broke loose.cuss a little.....it seems to help :)
  14. May 8, 2011 at 5:34 AM
    John3
    John3 Well-Known Member
    Maryland
    Barcelona Red 2010 DCSB TRD Sport
    OME 884X Coil Springs, CS047 Dakar Leaf Springs, 90000 Nitrocharger Sport Front Shocks and N182 Nitrocharger Rear Shocks, Light Racing UCAs, WeatherTech Floor Liners, Leer 100XQ Cap, 3/4" Plywood Carpeted Bed Platform, Thule Rack System w/4 Rocky Mounts PitchFork bike mounts, Pop & Lock PL5300, rcbs204 4x4 Illuminated Switch Mod, Dome Light Mod, Fog Light Mod, FLYZEYE Designs TCMA-0511 V2W LED Light, Go Rhino Dominator II SideSteps, HitchSafe, Console Vault, Fumoto F-103N Oil Drain Valve
  15. May 8, 2011 at 5:42 AM
    samsung
    samsung Well-Known Member
    George
    Sugar Land, Texas
    2011 PreRunner doublecab TRD Offroad
    undercover lid/Ipod integration kit/Pop n lock/bed rug, fumoto drain valve, full piping Wet Okole covers, Blacked out badges, Lamin-X fog light cover yellow, window tint, ARB deluxe bumper with fog light kit,DSM UCA'S,3 support shrockworks sliders,complete OME lift with 886X coil and dakar leaf spring with 3 degree axle shims and center pin lenghtener,warn VR10000 winch,amsteele blue synthetic rope, daystar winch isolator, daystar delrin rollers, IPF 900xs Extreme Driving H9 Kit 900XSD (900XSD),Horn on fire with shot Penning,
    i just did my first oil change last friday. My was really tight in there as well. try drilling a small hole on top of the filter to break the vaccum seal and remember righty tighty left loose. when you put the new one in just hand tighten the filter. good luck
  16. May 8, 2011 at 5:52 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    Try the lazy mans way for the first time.Let a reputable shop do it. Not iffy lube etc..
  17. May 8, 2011 at 6:55 AM
    tx_shooter
    tx_shooter This place is a cesspool of bfo and spacer lifts
    Try stopping by the local Harley shop and picking up an oil filter socket. The stock Harley oil filter for the Evos and Twin Cams is the exact same size (and will actually screw onto the truck) as the Mobil 1 oil filter. When I have a hard time getting the oil filter off I just use my oil filter wrench (end cap style) for my bike. No screwdrivers, no extra mess, and it comes right off.
    http://www.harley-davidson.com/gma/gma_product.jsp?WebLogicSession=L7oxFFlautetUhFcv85mJtANTp35nUmwvJryoR3NL7ornbMoudFX!819003505!hiwpbmsp01.ihd.hd!7005!8005&PRODUCT%3C%3Eprd_id=845524448774816&FOLDER%3C%3Efolder_id=2534374302491575&ASSORTMENT%3C%3East_id=2534374302491575&bmUID=1266362609932&bmLocale=en_US
  18. May 8, 2011 at 7:23 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    The correct size socket style unit works everytime. However I've been there with screwdriver stabbing...:D
    Like mentioned if you lube up the gasket seal on the new filter and get your filter on solidly hand tight, you should be fine. Racing, hardcore offroad stuff you may want to lightly wrench the filter on, or get filters with a nut welded on the outside with a hole drilled thru it for a lanyard, so the filter could loosen perhaps slightly, but never fall off.
  19. May 9, 2011 at 11:49 AM
    nOLd
    nold
    Dallas
    I finally got it removed it took me 2 days!!! :D I didnt want to put a hole on the oil filter. I had to call my dad to help me with some muscle, my arms was sore the 2nd day :D we used the Autozone OEM adjustable oil filter remover and use a long wrench socket for more torque. :)
    Thanks again guys for your advice...
  20. May 9, 2011 at 11:52 AM
    SOSHeloPilot
    SOSHeloPilot Well-Known Member
    U.S.A.
    2016 SR5, AC/LB, 4x2, V6, Auto, w/Tow, SiriusXM, Stock
    UnderCover SE, Bed Mat, Tint, Weather Techs & DashGoPro
    ... ^^^ ... this is what I have for stuck filters ... otherwise, I use a "sticky rubber glove" to take them off and put them on.
