need help, rounded bolt head!
Discussion in '1st Gen. Tacomas (1995-2004)' started by devilsalmostfree, Jun 26, 2010.
  1. Jun 26, 2010 at 8:21 AM
    devilsalmostfree
    devilsalmostfree [OP] Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    ok, changing the fluid in the rear-end yesterday. rounded off the fill plug head, thanks to the good ole 12 pnt. socket. ive tried a pipe wrench & a chisel with a hammer. cant seem to budge this thing! need some help. thanks.
  2. Jun 26, 2010 at 8:39 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I hope you didn't remove the drain plug first......
    **Spray some PB blaster on it and let it soak for 15 minutes or so.
    **Try putting a vice grip on it, really really tight.
    **Try using a file, and file off the edges to make them 'square' again in hopes you can get any kind of 6-point socket on it. File it enough to get down to the next smallest socket size if you can (metric or standard).
    **If you can file the edges down to the next size with a good tight fit, then hopefully you have (or know someone) who has an air compressor and impact wrench you can try on it.
  3. Jun 26, 2010 at 8:41 AM
    micropiper
    micropiper Admiral of the JOLLY ROGER navy
    damion
    phoenix az
    Four cylinders of pure awesome
    k&n air filter in a modded intake, sliders, new horn, plenty o pinstripes, custom onboard air,cobra cb with custom skidplate,
    Got access to a welder? If so zap another nut on the top. TA-DA! If not im not sure anybody else?
  4. Jun 26, 2010 at 8:49 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Once you get it repaired enough to try again you might try useing a bottle jack under the wrench since there's not much space for leverage under there with a cheater bar.
  5. Jun 26, 2010 at 8:50 AM
    devilsalmostfree
    Carl
    Loudon, Tn
    yes, i did drain it 1st:facepalm:!
    i sprayed pb blast on it, let it set for a few.
    i will try to file & put a smaller socket on it. i went & bought a 24mm 6pnt socket. got it on there, still not budging. started slipping off after trying it a time or 2.
    i have an air compressor & impact wrench. guess i shoulda already tried that!
  6. Jun 26, 2010 at 8:53 AM
    devilsalmostfree
    Carl
    Loudon, Tn
    i might have to try that. just have to see if my friend can bring his over. thanks.
  7. Jun 26, 2010 at 8:53 AM
    devilsalmostfree
    Carl
    Loudon, Tn
    might have to try that!
  8. Jun 26, 2010 at 9:05 AM
    05 TRD Sport
    05 TRD Sport She's Fat, I'm Drunk, It's On.
    30 minutes south of Atlanta
    2016 SR5
  9. Jun 26, 2010 at 10:36 AM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    First try Vice Grips...If that doesn't work, get a small torch (doesn't have to be a torch set or anything, just a small propane torch will do) and head up around the bolt, and the head of the bolt. Then try with the Vice Grips again.
  10. Jun 26, 2010 at 10:53 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    +1 on irwin. Craftsman makes a rounded bolt remover too. Saved me a few times.
  11. Jun 26, 2010 at 10:55 AM
    devilsalmostfree
    Carl
    Loudon, Tn
    no one around here has 1 in stock.
    got my friends torch, tried the vice grips, bout to go combine them 2 together. this is shitty!
  12. Jun 26, 2010 at 10:57 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Tapping the head with a hammer will help dislodge some of the rust.
    Not too much heat or beating, though.
  13. Jun 26, 2010 at 11:03 AM
    moe1967
    moe1967 Well-Known Member
    2010 TRD DC Off-Road PreRunner
    Hammer a socket on to it, then use an impact wrench.
    I had this done when the key for my locking lug nut broke on my 4runner. It worked like a charm.
  14. Jun 26, 2010 at 11:17 AM
    devilsalmostfree
    Carl
    Loudon, Tn
    think im just going to get my friend to weld a nut on it for me tomorrow. im done with it for today!
  15. Jun 26, 2010 at 11:22 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Nooo wait, try this first, take a socket the closest size to it, and fill it full of Jb weld, hammer it on there the best you can and let it sit the instructed time and then it should just come right out
  16. Jun 26, 2010 at 11:43 AM
    devilsalmostfree
    Carl
    Loudon, Tn
    have u done this before? it says, "allow 4-6 hrs to dry before handling. allow to drive overnight(approx. 15hrs) before putting object to use."
  17. Jun 26, 2010 at 4:48 PM
    devilsalmostfree
    Carl
    Loudon, Tn
    ok just now got it out! with an easy out, i was pretty hesitant of those things, but it did work. just wanted to let all of u know, & thanks for ur help!
  18. Jun 26, 2010 at 5:01 PM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    At Least you got it out. Next time anything like this happens, Try and TIGHTEN it first. If any resistance as you begin to loosen, go tight. Sometimes that will be just enough to break the bind. An old trick learned,taught and used in the Air Force wrenching jets.
    Just something to keep in your hat....
  19. Jun 26, 2010 at 5:46 PM
    devilsalmostfree
    Carl
    Loudon, Tn
    thanks, i learned that trick from a buddy that got outta the airforce a few yrs back. i did try it, but not until it slipped/rounded (a tad bit) the bolt 1st! after that, it was all over with.
  20. Jun 26, 2010 at 9:29 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    :woot::woot:That is worthy of a double wOOt! Surely, High Drama.
    Made my day......Living Vicariously the devilsalmostfree! :D
