need help, rounded bolt head!
Discussion in '1st Gen. Tacomas (1995-2004)' started by devilsalmostfree, Jun 26, 2010.
  1. Jun 26, 2010 at 10:57 PM
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    Bin those 12 point sockets.
    Use them only on loose stuff.
  2. Jun 27, 2010 at 7:42 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    x2
    12 points are best for 12pt bolts. Use it on square head, 6pt, and taps you might end up with more work, and cussing to do:rant:
  3. Jun 27, 2010 at 7:49 AM
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
    Thumbs up for a successful mission.
  4. Jun 27, 2010 at 8:05 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Never heard of a 12 point bolt. Got any pictures??
  5. Jun 27, 2010 at 8:23 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    No pics, but they use them on Detroit 71 series truck engines for the starter. They're not very common.
  6. Jun 27, 2010 at 8:27 AM
    maju
    maju Well-Known Member
    Davenport Fl
    2010 DC Silver TRD Sport 4x4
    Undercover tonneau, Scangauge II, Garmin GPS, Michelin LTX M/S2
    Here is a picture of a 12 point intake manifold bolt.
  7. Jun 27, 2010 at 9:19 AM
    Janster
    Jandy
    Lancaster, PA
    Thanks!
    The thing is..... 12 point sockets are more common than 6 point sockets. They're perfectly fine to use on any bolt. The point is - like TRAP already mentioned - 12 point sockets are for standard usage. If/When you run into a situation where a 12 point starts to round off the edges and/or you can't remove a bolt with a 12 point, its time to switch to a 6 point.
    Same situation when working with brake lines...if you can't get a flare nut off with a standard wrench, its time to start using a flare wrench.
  8. Jun 27, 2010 at 11:21 AM
    Barnone
    Barnone Guest
    Note to self. Remove fill bolt first.
    Anyway, glad you got it out.
  9. Jun 28, 2010 at 4:33 AM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    I know alot of driveshafts also have 12 point bolts
